Right Hand rule, explain please?
The right-hand rule is a method used to determine the direction of the cross product in a right-handed coordinate system. When applying the rule, the thumb represents the direction of the resulting vector, while the fingers indicate the rotation from one vector to another. For example, the cross product of the unit vectors i and j results in k, while j crossed with i results in -k. Visual aids, such as diagrams, can enhance understanding of this concept, as demonstrated in the discussion. Overall, the right-hand rule is essential for solving physics problems involving vector cross products.
elephantorz
[SOLVED] Right Hand rule, explain please?
I don't have a problem, I just have issues with understanding the right-hand rule, if someone could explain it (with pictures if possible) I would appreciate it, although it might be better in person because I could see the motion.
Consider the following diagram,
The right-hand rule is defined such that it conforms to the right-hand coordinate system. In the right-handed coordinate system with the usual unit vectors (i, j, k) the cross product between i and j gives, by definition, k,
i X j = k
Which simply means that if one rotates the x-axis counter-clockwise by \pi/2 such that it lies collinear with the y-axis, then the result is the z-axis. The right-hand rule is commonly used to determine the direction of a cross product, especially in physics problems.
Consider the cross product describe above (iXj), which basically means rotating the vector i (the x-axis) toward the vector j (y-axis). Now, take your right-hand and keeping your thumb straight (as if giving the 'thumbs up') curl your fingers in the direction which the x-axis is rotating (in this case toward the y-axis). Your thumb should now be pointing straight upwards, in the direction of k (the z-axis).
Now consider the following cross product,
j X i
Using the same method as above try to curl your fingers in the direction of rotation (i.e. from the y-axis to the x-axis), you'll probably find that you'll have to turn your hand upside down. If you have done it correctly, your thumb should be pointing direction downwards (towards the negative z-axis). Hence, you have used the right hand rule to determine the cross product,
j X i = -k
Indeed, it is very difficult to describe the right-hand rule without demonstrating it. However, I hope you've found my post useful.
It was, very useful, I had never had it explained to me like that, which makes more sense seeing the diagram, thanks!
Glad to be of service :smile:
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
