River channel problem using Bernoulli and Continuity
4 replies · 4K views · last reply
tere_lai
[SOLVED] River channel problem using Bernoulli and Continuity
A river (100 m wide) flows through its rectangular channel at a depth of 2.560 m at a velocity of 2.050 m/s. What is the velocity of the discharge if the channel is narrowed to 90 m?
Continuity equation: Q1 = 100m x 2.560 m x 2.050 m/s
Q2 = 90 m x H2 x V2
Bernoulli equation: V^2/2g + P/pg + z = constant
I can't seem to set up the equations properly in order to find intercept. I'm sure that P1 (ie. pressure1) is zero, but P2 isn't. I actually tried solving the question with P2=0 but it's wrong.
A little help?
(you may have seen this in "Introductory Physics" but I don't know how to move/delete the previous thread, sorry)
Hey there, in open channel flow usually the version of Bernoulli equation used is:
[tex]y + \frac{v^2}{2g} + z = constant[/tex]
In your case the z value probably can be ignored assuming the river doesn't have any vertical variations in its geometry. You could use this equation which is also known as the specific energy.
[tex]y + \frac{v^2}{2g} = constant[/tex]
The height of the water (z) is assumed to change due to the narrowing of the river channel. I think I know how to answer the question now...
Great!, good luck, if you have more questions feel free to ask them.
