I Calculating the Area of an RN Event Horizon with Specific Heat Formula
etotheipi
By definition ##C = T_H \dfrac{\partial S}{\partial T_H} \bigg{)}_Q## so given ##A=4S## we first need to work out the area of the event horizon. More specifically, let ##\Sigma## be a partial Cauchy surface of constant ##v## in ingoing EF ##(v,r,\theta, \phi)## co-ordinates then ##A## is the area of the 2-sphere ##\Sigma \cap \mathcal{H}^+##. This is where I get confused, because since ##g = -\dfrac{\Delta}{r^2} dv^2 + 2dv dr + r^2 d\Omega^2## surely we could just let ##(\theta, \phi)## be co-ordinates on ##R## with ##\sqrt{h} = r^2 \sin{\theta}## and hence ##A = \int_{\varphi(R)} d\theta \wedge d\phi \sqrt{h} = 4\pi r^2##, which must be wrong. How do you actually calculate the area of ##R##?
Actually, maybe it's not wrong? We can try to figure out ##T_H## by using the identity ##d(\xi^a \xi_a)_{\mathcal{N}} = - 2\kappa \xi## and for RN we have a timelike Killing vector ##k =\partial / \partial v## so\begin{align*}
d(k^a k_a) = d(g_{ab} k^a k^b) = d\left( \frac{-\Delta}{r^2} \right) = \left(\frac{2\Delta}{r^3} - \frac{1}{r^2} \dfrac{d\Delta}{dr} \right) dr
\end{align*}and since ##k = dr## at ##r=r_{\pm}## we have ##\kappa = \dfrac{r_+-r_-}{2r_+^2}## and ##T_H = \dfrac{\kappa}{2\pi}## so\begin{align*}
T_H = \frac{1}{2\pi} \left( \frac{\sqrt{M^2-e^2}}{2M^2 -e^2 + 2M\sqrt{M^2-e^2}} \right)
\end{align*}I think the rest should be straightforward using ##A = 4\pi \left(2M^2 - e^2 + 2M\sqrt{M^2-e^2} \right)##, but I'll try that later because I have a call now
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
