Affordable DIY Robotic Arm Project for Beginners | Step-by-Step Guide
  • Thread starter Thread starter ttouch
    Arm Project
Building a DIY robotic arm for around $60 is feasible, but lifting 500g may require more robust components, possibly hydraulics. Using four servos for movement is a good plan, but larger, more powerful servos are recommended, along with an external battery to power them. The suggested material, a 1m aluminum tube, is lightweight and suitable for the arm's structure, but the challenge lies in creating effective joints and connections. The builder lacks experience with design software like AutoCAD but intends to construct the arm manually. Overall, the project is possible with careful planning and the right materials.
ttouch
Hello,
I'm a complete noob on the robotics.
I got an idea, to build a really cheap robotic arm (~$60). I thought about using 4 servos (rotate the arm, move up/down the first part, move up/down the second part and open/close the grippers). As the bone material I found that 1m aluminium tube (2mm thick wall and 5cm diameter) costs about 5$. I don't want the arm to be very big, so the first part could be 40cm and the second 30cm.
Also I need it to be able to lift 500g (is that a bit too much?)
I have an Arduino which is ok for controlling some servos.
I know I don't give enough data, but that is just a thought. I have no idea how to design it in the computer (zero knowledge of AutoCAD)
Problems:
Is this even possible? (I don't see any problems, but as said, I'm a noob)
What servos do I need? How much torque? (aluminium is very lightweight...)
Thank you
Well I think it is possible but maybe not a 500g load unless you are using hydraulics. I was actually on a science Olympiad team in high school and was given the task to build a robot arm from scratch. I used arduino and as far as the servos go I used Futaba S3003's (Not very powerful). For the body I used a kit I found online it was made of laser cut wood. To control it I used 2 joysticks from a ps2 controller.
I actually happened to have made a video of the arm on youtube a wile back if you want to watch it the link is here-
As far as your robot I think it would be possible to build it out of that tube but I was wondering what kind of resources you have available like do you happen to have access to a laser cutter, how do you plan on building the skeleton?
As far as servos go you are going to want to use large ones. Also you will need an external battery for the servos because the arduino can't handle more than about 2 small ones and I think but make sure you remember to connect the ground from the arduino and the ground on the battery haha that always gets me lol.
If you want to you can just buy the skeleton already created with all the servos that work with it.
Here is a ebay link http://www.ebay.com/itm/New-6-DOF-M...011?pt=LH_DefaultDomain_0&hash=item3cd13fef9b
Hope this was somewhat helpful
Thank you for the reply.
I want to build the skeleton on my own. I was thinking about buying 2m aluminium tube and cut it with a saw. The only problem is the connections between the arm, but I'll find a solution...
I have no laser cuter access and I don't want to buy a ready body.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
