Robotics DC Motor Help: Testing Motors for Project
The motors being tested for a robotics project are underperforming compared to their specifications, showing significantly lower torque and higher current draw than expected. The testing setup involves a 7.2V LiPo battery directly connected to the motors, with torque measured using a mass and string method. Despite the motors having a stall torque rating of 125 oz*in, the calculated torque with a 600g mass is only 39 oz*in, indicating a performance issue. Gear slippage is noted as a potential weak link, but the current draw of 600 mA suggests the motors should still be capable of more torque. Concerns are raised about the battery's ability to deliver sustainable current, which could affect motor performance.
jessicadrew
I'm currently trying to test the motors I bought for a robotics project to see if they'll work for our application and they seem to be much weaker than what should be expected based on the specs. During test, the battery is hooked directly to the motor and I'm measuring the current draw and the torque supplied to the wheel. The battery is a 7.2V 5Ah LiPo, so it should be able to much more current than what is needed for one of these motors.
The motors have the following specs at 6V (though it can be safely ran between 3 to 9V):
Free run current: 70 mA
Stall current: 1.6 A
Stall Torque: 125 oz*in
I'm measuring the torque on the motor by attaching a mass to a string and having the string wrap around the wheel and using the equation T=F*r=mg*r, where r is the radius of the wheel.
When testing the motors, the gears begin to slip with a 600g mass attached to the string. My calculations here are:
F=(.6 kg)*(9.81 kg/s^2)=5.9 N=17.9 oz
So,
T=(17.9 oz)*(2.16 in)=39 oz*in which is well below the maximum rated torque of the motor.
With the 600g mass the current was about 600 mA, which also suggests that I'm far from the maximum motor torque.
These results seem to imply that the motors are not performing as specified, but I wanted to make sure that I'm not doing something wrong while testing or with my calculations.
As a side note, these motors do have a 1000:1 gear ratio, so it makes sense that the gears would be the weak link, but only being able to get 30% of the specified torque seems extremely low.
Any ideas would be greatly appreciated.
Doesn't sound to me like a battery problem but I do note that you have said nothing about what the battery is capable of producing in sustainable current. That is, it COULD be (seems unlikely) that the 5Ah rating is only good as long as you keep the battery to 10 ma and it has a peak current output of 20 ma (I'm using ridiculously low numbers here just to make the point).
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 17 ·
  • · Replies 23 ·
