Rocket Launch: Solving for Height and Time
The discussion revolves around a physics problem involving a rocket launched with an acceleration of 10 m/s² for 20 seconds before the motors turn off. The initial velocity is calculated to be 196 m/s, leading to a height of 1960 m after accounting for the effects of gravity. Participants clarify that the rocket continues to ascend after the motors stop, and the final velocity will not be zero immediately after 20 seconds. The focus is on understanding the coasting phase and how to calculate the total height and time until the rocket reaches its peak. The conversation emphasizes the importance of correctly applying acceleration values during different phases of the rocket's flight.
Dinovek
A rocket is launched off and accelerates vertically up at 10 m/s 2. At 20 seconds, the motors are turned off, but the rocket keeps going up.
a) What height did it reach?
b) What was the time it needed to reach that height?
g: - 9.8 m/s2
a: 10 m/s2
final velocity: 0 m/s (Not sure).
t=20 s
h= vo (t) + g(t)2/2
t=(vf-vo)/g
vo= vf-g(t)
I needed to find initial velocity to find height so I did.
vo=vf-g(t)
vo= 0 m/s - (-9.8m/s2)(20)
vo= 196 m/s
Now I just substituted to find height.
h= vo(t) + (g (t)2)/2
h= 196 m/s (20s) + (-9.8 m/s2 (20) 2)/2
h=3920 m + -3920 m/
h= 3920 m - 1960 m
h= 1960 m
I really have no clue how do to even start the problem because I'm not sure what is the time total. I was thinking that after it stops accelerating, every second it decreases 1 m/s on it's acceleration so that would 10 more seconds to the total timing.
Any help would be appreciated it. Thanks.
Why did you use g for acceleration during the first 20 seconds? The rocket is accelerating at +10m/s2 during the first 10 seconds.
You would use g for acceleration after the 20 seconds, since that's when the motors are off.
You're right, I didn't read carefully, thanks! I'm not sure how I'm going to calculate the total height. How do I know when it's going to reach final velocity of zero?
You first have to find the height it reaches in the first 20 seconds. Vf will not be zero after 20 seconds. After 20 seconds it is coasting (like a car when you take your foot off of the gas). It will take more time for it to reach 0 m/s (maximum height).
Try solving the coasting part on your own, and post back if you get stumped. Hint:
Vf when the motors are going will be Vo when the rocket is coasting.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
