How Do You Calculate the Velocity of a Rocket Facing Air Resistance Over Time?
  • Thread starter Thread starter kraigandrews
    Force Rocket
To calculate the velocity of a rocket facing air resistance over time, one must consider the mass loss due to exhaust ejection and the retarding force from air resistance. The differential equation governing the rocket's motion is derived from Newton's second law, incorporating both gravitational and drag forces. The terminal velocity can be determined using the formula (γu - g)/b, where u is the exhaust speed, γ is the mass loss rate, and b is a constant related to air resistance. The discussion highlights confusion in solving the differential equation, particularly in applying the product rule correctly when mass is not constant. Ultimately, understanding the net forces acting on the rocket is crucial for accurately determining its velocity over time.
kraigandrews
A rocket ascends from rest in Earth's gravitational field, by ejecting exhaust with constant speed u. Assume that the rate at which mass is expelled is given by dm/dt = −γm where m is the instantaneous mass of the rocket and γ is a constant; and that the rocket is retarded by air resistance with a force mbv where b is a constant.
Determine the velocity of the rocket as a function of time. Here is a hint: The terminal velocity is ( γu−g )/b.
Calculate the time when the velocity is one-half of the terminal velocity.
Data: u = 31.9 m/s; b = 1.2 s−1.
dp/dt=m(dv/dt)
I got the diff eq down to:
dv=-u(dm/m)-(g+bv)dt
I'm not quite sure what I am doing wrong, I divide by -(g+bv)
then solve from there to get -b*ln(g+bv)=uγt, but for some reason I don't think this is correct. Help, thanks.
Do we take into account the fact that F_g = GMm/x^2 changes as the rocket goes higher, or are we assuming a constant F_g = mg?
assume Fg= -mg
Alright. It's not working out for you because you have misapplied Newton's law: F = \frac{dp}{dt} = \frac{d}{dt}(mv) = m\frac{dv}{dt} + v\frac{dm}{dt} by the product rule. Usually, m is constant, so dm/dt = 0, but in this case, dm/dt is given to be -γm.
Also, what is the net force on the rocket?
Fnet=-mg-mbv
so dp/dt=F gives you :
(-mg-mbv)dt=mdv+udm
then,
dv=uγ-(g+bv)dt
that's right I just don't know how i keep messing up on solving the diff eq
If have close pipe system with water inside pressurized at P1= 200 000Pa absolute, density 1000kg/m3, wider pipe diameter=2cm, contraction pipe diameter=1.49cm, that is contraction area ratio A1/A2=1.8 a) If water is stationary(pump OFF) and if I drill a hole anywhere at pipe, water will leak out, because pressure(200kPa) inside is higher than atmospheric pressure (101 325Pa). b)If I turn on pump and water start flowing with with v1=10m/s in A1 wider section, from Bernoulli equation I...
  • · Replies 23 ·
