Rolle's theorem -> Differentiability
3 replies · 2K views
Spiralshell
So I'm doing problems where I have to verify Rolle's hypotheses. I am only having trouble with the differentiability part. My professor wants me to prove this. So for example,
f(x)=√(x)-(1/3)x [0,9]
none
1.) I know the function is continuous because root functions are continuous on their domains and polynomials are continuous everywhere therefore the difference of two continuous functions is continuous.
2.) What could I say about it being differentiable?
My GUESS: it is defined everywhere on its domain [0,9] and continuous it is therefore differentiable on its domain [0,9]?
I am only stuck on 2.) so no need to go further on the problem.
No. Saying that a function is "defined and continuous" on a domain does NOT mean that it is differentiable on the interval. For example, |x| is "defined and continuous" for all x but is not differentiable at x= 0.
It's hard to tell you how you should answer this without knowing what you about derivatives. IF you know that the derivative of [itex]x^n[/itex] is [itex]nx^{n-1}[/itex] then it should be easy to tell what the derivative of [itex]x^{1/2}- x/3[/itex] is and so where it is differentiable.
(It is NOT differentiable on [0, 1] but Rolle's theorem does not require it to be.)
I know the derivative to the function. I also know chain rule and the limit definition as well quotient rule, etc. So the way my professor explained is that I have to verify I can differentiate over the interval given. In this case [0,9].
So I know f'(x)=1/(2√x)-(1/3)
I just don't understand how I verify that is differentiable over [0,9].
Here is how he gave me Rolle's Theorem (very simply):
1.) f is continuous on [a,b] (Prove it!)
2.) f is differentiable on (a,b) (Prove it!)
3.) f(a)=f(b) then if all 3 conditions are met a<c<b such that c belongs to (a,b) and that f'(c)=0.
I hope this helps you understand my situation. I am only stuck on 2.)... The rest is I understand.
Also, thank you for replying. I appreciate all the help I can get.
Well, you have computed a formula for the derivative. Are there any values of ##x## in ##[0,9]## that cause problems?
