Rolle's theorem, to show there's only one root
18 replies · 5K views · last reply
Karol
Textbook excerpt listing three functions f(x) with interval pairs a and b, asking to show each has exactly one real root between them; item 3, 2x^3 - 3x^2 - 12x - 6 with a = -1, b = 0, is boxed in red.
Rolle's Theorem:
If f(a)=f(b)=0 then there is at least one a<c<b such that f'(c)=0
$$y=2x^3-3x^2-12x-6~\rightarrow~y'=6x^2-6x-12$$
The function:
Graph window plotting f(x)=2x^3-3x^2-12x-6 as a red curve over x from about -1 to 0.4, crossing the x-axis near x = -0.7; the curve falls to y = -5.50 at the cursor point x = -1.138.
y':
Graph window plotting f(x)=6x^2-6x-12 as a red curve over x from about -1.4 to 0.4, with y-axis labels -5 and -10 and the curve falling steeply to the right of x = -1.
How do i know y' isn't 0 somewhere? if it's continuously descending, so i make y''=12x-6. it's a straight line, so there are no twist points in y'.
But to know y'' doesn't equal 0 somewhere i take y'''=12
Do i really need to reach y''' in order to answer the question? i think i exaggerate
  • Textbook excerpt listing three functions f(x) with interval pairs a and b, asking to show each has exactly one real root between them; item 3, 2x^3 - 3x^2 - 12x - 6 with a = -1, b = 0, is boxed in red.
  • Graph window plotting f(x)=2x^3-3x^2-12x-6 as a red curve over x from about -1 to 0.4, crossing the x-axis near x = -0.7; the curve falls to y = -5.50 at the cursor point x = -1.138.
  • Graph window plotting f(x)=6x^2-6x-12 as a red curve over x from about -1.4 to 0.4, with y-axis labels -5 and -10 and the curve falling steeply to the right of x = -1.
You are trying to show there's only one real root. That is where ## f(x)=0 ## for some ## x ##. ## \\ ## The way this can be readily shown is if ## f(a)>0 ## and ##f(b) <0 ## and ## \frac{dy}{dx} < 0 ## over the entire interval. ## \\ ## Alternatively, if ## f(a)<0 ## and ## f(b)>0 ## then ## \frac{dy}{dx} > 0 ## for the entire interval will guarantee there is only one root.
Karol said:
Rolle's Theorem:
The function:
y':
Factor ##\ 6x^2 - 6x -12\ ## to find where the first derivative is zero.
Y'=0 at a=(-1)
How do i prove y'≠0 on the rest of the open domain <a-b>
y' only has two zeroes, can you find the other one?
Karol said:
Y'=0 at a=(-1)
At how many points is y' = 0 for this function (in part c)? Have you investigated the intervals on which the function is increasing or decreasing?
BTW, the theorem is Rolle's Theorem. I will correct things in your thread title and elsewhere.
Karol said:
Y'=0 at a=(-1)
Did you follow @SammyS suggestion in post #3? That will answer your question.
y'=0 at x=(-2) and x=3, between them y'<0 so y is decreasing
So between a=(-1) and b=0 y decreases
I don't need y''
No, neither of your x values is correct. See SammyS's post #3 and show your work.
I don't need y''
$$y'=6x^2 - 6x -12$$
$$\left\{ \begin{array}{l} x_1+x_2=-\frac{b}{a}=1 \\ x_1\cdot x_2=\frac{c}{a}=(-2) \end{array}\right.$$
$$x_1=(-1),~x_2=2$$
And in between y'<0 so y is decreasing, but it doesn't matter since the theorem only demands y'≠0 in the open interval
$$x_1=(-1),~x_2=2$$
Those are the correct values for which y' = 0, but why must it be that y has to be zero between x = -1 and x = 0?
Your thread title mentions Rolle's Theorem, but I don't see that this theorem is applicable in your problem. More to the point would be the Intermediate Value Theorem.
The author of the problem was probably thinking about the not more than 1 zero part. The IVT gives you at least one zero and if you had two then Rolle's Theorem comes into play.
Yes, with the Intermediate Value Theorem:
Printed text of a theorem statement: Rolle's Theorem combined with the Intermediate Value Theorem to isolate real roots of f(x) = 0, listing conditions a, b and c on f, f' and the interval from a to b, concluding there is exactly one zero of f between a and b.
So i even don't need to prove y decreases (by proving y'<0)
  • Printed text of a theorem statement: Rolle's Theorem combined with the Intermediate Value Theorem to isolate real roots of f(x) = 0, listing conditions a, b and c on f, f' and the interval from a to b, concluding there is exactly one zero of f between a and b.
You may not " need to prove y decreases (by proving y'<0). "
However, the fact that ƒ'(x) < 0 for x ∈ [ −1, 2 ] is a reasonable way to show that ##\ f(x)=2x^3-3x^2-12x-6 \ ## decreases on that interval, so ##\ f(x)\ ## has at most one zero on that interval.
That together with the Intermediate Value Theorem is sufficient to satisfy the given problem.
This is exactly what I had in mind in my previous post.
Why with the Mean Value Theorem and Rolle's Theorem there is only one root (y=0) if f(a) and f(b) have opposite signs?
The Mean Value Theorem says there is at least one root, what is the role of Rolle's theorem in that there is only one root? why does it make this if y'≠0?
Rolle's theorem is applicable if f(a)=f(b)=0, here they aren't
@Karol, you know that f(-1) > 0 and f(0) < 0, and that f is decreasing on the interval [-1, 0], and that f is continuous for all real numbers. The Mean Value Theorem guarantees that f will take on all values between f(-1) and f(0), so for some number c, f(c) must be zero. Because f is decreasing on the interval [-1, 0], it can't cross the x-axis twice, thus there can be only one zero on that interval.
We are talking about this particular function on this particular interval. If f(a) and f(b) have opposite signs the IVT guarantees at least on root between a and b. There may be more.
No, you mean the Intermediate Value Theorem (IVT), not the mean value theorem.
To show this function doesn't have more than one root, there are two ways. One is to note the function is strictly decreasing so it couldn't have two roots. The other is to suppose it does have two roots, by way of contradiction. In that case Rolle's theorem would give another zero of f'(x) which gives a contradiction for this function.
[Edit:] Apparently Mark44 and I were typing at the same time.
