Room temperature superconductor paper published
The recent paper claims the successful synthesis of a room-temperature superconductor (Tc≥400 K) using a modified lead-apatite structure (LK-99) at ambient pressure. While the authors present evidence for superconductivity, including zero resistivity and the Meissner effect, skepticism exists regarding the clarity of their data and the authors' lack of experience in experimental superconductivity. The simplicity of the synthesis process raises hopes for replication, but concerns linger about the validity of their claims and the potential for false alarms, as seen in past announcements. Some discussions highlight the challenges of commercialization and the need for clear phase transition data to substantiate the findings. Overall, the scientific community remains cautious, awaiting independent verification of the results.
BWV
This paper is circulating around fintwit , has not been replicated, but does it pass a smell test?
https://arxiv.org/abs/2307.12008
The First Room-Temperature Ambient-Pressure Superconductor​
Sukbae Lee, Ji-Hoon Kim, Young-Wan Kwon
For the first time in the world, we succeeded in synthesizing the room-temperature superconductor (Tc≥400 K, 127∘C) working at ambient pressure with a modified lead-apatite (LK-99) structure. The superconductivity of LK-99 is proved with the Critical temperature (Tc), Zero-resistivity, Critical current (Ic), Critical magnetic field (Hc), and the Meissner effect. The superconductivity of LK-99 originates from minute structural distortion by a slight volume shrinkage (0.48 %), not by external factors such as temperature and pressure. The shrinkage is caused by Cu2+ substitution of Pb2+(2) ions in the insulating network of Pb(2)-phosphate and it generates the stress. It concurrently transfers to Pb(1) of the cylindrical column resulting in distortion of the cylindrical column interface, which creates superconducting quantum wells (SQWs) in the interface. The heat capacity results indicated that the new model is suitable for explaining the superconductivity of LK-99. The unique structure of LK-99 that allows the minute distorted structure to be maintained in the interfaces is the most important factor that LK-99 maintains and exhibits superconductivity at room temperatures and ambient pressure.
Likes James Pryor, pinball1970, Rive and 1 other person
lol, posted it earlier today, but decided to delete the post :smile:
Good thing is that the chemistry behind makes it easy to test, any decent lab should be able to reproduce the material in days. OTOH it wouldn't be a first false alarm.
Probably not last either.
We need a 'fingers crossed' response too.
  • Haha
Likes PhDeezNutz, pinball1970, BillTre and 1 other person
I would definitely like to see their results replicated.
I'm not sure it will be that easy.
The recipes listed in the paper look pretty simple. Sure, things can get hairy somewhere, but that would be already a signal something is wrong.
There is something very quick and simple: borrow their "rock" and test it.
If you can find another suitable lab in Seoul, it could be done today.
Likes russ_watters and Anixx
Except that it's already tomorrow in Korea. :smile:
  • Haha
Likes BillTre and berkeman
This didn't happen with the last time we had the first room temperature superconductor, the Indian gold-silver amalgam. Or maybe it was the time before that.
Does this pass the smell test? It's pretty stinky. Doesn't make it wrong, but...
  1. The paper, as stated, is not very good. Doesn't make it wrong, but...
  2. The evidence plots are, at least to me, not so clear. Doesn't make it wrong, but...
  3. The authors' publication history is not in experimental superconductivity - it appears to be more in theory, and non-SC theory dominates. Doesn't make it wrong, but...
  4. The research was apparently conducted at a commercial company, This appears to be the very first paper out of this company, at least in English. Doesn't make it wrong, but...
  5. The idea of increasing the internal pressure by substitution is not new. It has had some success in the past, but nothing like this. Doesn't make it wrong, but...
  6. The authors claim to have a new family of materials. The first and thus far only member of this family has the property of interest. Doesn't make it wrong, but...
You may be sensing a theme.
Likes BWV, Bystander and berkeman
7. They made a video that is supposed to show levitation but the object is resting on the surface on one side. It looks like a normal repulsion between magnets.
8. They made a video how their object wiggles a bit in response to a moving magnet nearby, but that's something you get with regular metals as well.
9. Their resistivity measurement below what they call critical temperature is 1000 times higher than the resistivity of copper. It decreases with decreasing temperature, just like for regular metals.
Likes dsatkas and berkeman
Can you be a bit more specific about this citation? I agree with your other stuff but I do not see this one and I was indeed looking.
10. They filled the patent application for superconductivity in LK-99 in 2020. So, in 3 years they could not make a perfect specimen?
I do not believe a material can be patented. A process for making it, yes, and in some cases a use for a material, but I do not believe you can patent the material itself.
They can always file....
I am not a parent attorney. But my understanding is that you can (perhaps) patent a material for a given use, but not for any use whatever. (It's a floor wax! It's a dessert topping!) I am really not an expert in Korean law, but most 1st world nations have similar patent laws.
Some of the peculiarities might be explained by this being an attempt to avoid assigning ownership to their university. Typically in the US, the terms of employment assign intellectual property to the employer, but equally typically the inventor gets a piece of the pie, e.g. 25%,
They'll starve with only 25% of a patent that (if it's working and the patent is enforceable) is worth hundreds of billions of USD.
I doubt the patent - if it is even granted - is worth billions. The market for SC cable is just over $1B/year. Assuming they get can 1% of this, that's $10M/year. Not a bad chunk of change, but not billions.
That's assuming that the manufacturing capacity ramps up to today's HTS capacity quickly, and it also assumes a major world power (I have one in mind) doesn't just decide to infringe. Further, an agreement gets money flowing to all the parties faster than litigation.
One other thing bothers me. What is Tc? The paper just says>=400 K (127 C), That by itself looks innumerate, but stay with the >=400 K for a moment. Why can't they give a better answer? Phase transitions are easy to spot.
The answer is that they don't have a sharp transition. I'd sure want to see one or have a doggone good understanding of why I didn't see one before claiming that there is one.
That's with current superconductors where you need liquid nitrogen or even liquid helium to operate them. A room temperature superconductor that is easy to manufacture and doesn't need cooling under most conditions would grow that market massively. We lose around a trillion kWh in transmission per year. At a market price of maybe 5 cent/kWh that's 50 billion per year. You won't replace the grid over night, but year for year you can unlock more of that potential by upgrading your infrastructure.
There are completely new markets, too. You can connect continents to share renewable energies in a more balanced way for example.
Maybe slightly different thresholds in different samples? Figure 5 shows a very sharp transition.
Sure, maybe a new material will cause the market to balloon. Didn't happen with Nb3Sn, Didn't really happen with HYS - MRI magnets are still wound with Nb-Ti - but maybe this tile it will be different. Even regular SCs took decades to be commercialized, If there is a theme, it's that making a sample of an SC material is one thing, Making wire is something else entirely, and making long wires is yet again something else. Maybe this time things will be different,.
We've had HTS for over 30 years. It still is a niche market - mostly leads to coils of Ni-Ti. Patents are 20 years. Maybe this time things will be different,.
Maybe, That does not bode well for fast commercialization. The only company that has been successful marketing a product where sometimes it works and sometimes it doesn't is Microsoft. :smile:
Reminds me of a great headline: Scientists in the Antarctic discover a room-temperature superconductor.
Superconductive levitation must be full-levitation. Half-levitation is a characteristic of a weak magnetic dipole resting on the pole of a bigger magnet.
That has now given away the trick they are using.
Maybe they are yet to realise, they are kidding themselves.
I'm not sure I buy that. (Presumably non-superconducting) frogs can be levitated, and floating means that gravitational potential enerhg can be overcome by magnetic energy density - not true for all materials: only party might be in the SC phase (or I suppose, if it's really heavy). SC cable, for example, typically doesn't float, as the weight is mostly stabilizer.
That said, there's something Monty Python-esque about levitating a sample, um, one side at a time. "the only reason that it had been sitting on its perch in the first place was that it had been nailed there."
Some of the finance people I follow on Twitter (X?), no doubt applying the deep expertise in submarine design they developed earlier this summer to the field of solid state physics, are citing this paper as replication:
https://arxiv.org/abs/2307.16892
  • Haha
Likes russ_watters, Haborix and BillTre
Even some sophisticated scientists I've known have regarded numerical simulations as "experiments." That always seemed strange to me. But I yield to the advanced wisdom finance bros.
Likes russ_watters and BWV
Well, when has numerical modelling ever failed in finance?
  • Haha
Likes hutchphd, russ_watters and mfb
Cataclysmic failures are above my paygrade, sorry.
When I was younger, I always wondered how a stranger could come into a town, and get people to buy the snakeskin oil. After seeing how this has played over social media, I realize it is because some people want to be deluded into something, and that is what the snakeskin oil salesman is really selling.
I saw some guy on twitter take a picture with a ceramic bowl, a blowtorch, and later a piece of metal in a glass pipe and people seriously thought he was making the material. Shockingly enough, he is now thinking of ways to take donations!
  • #32
DaveC426913 said:
Sounds like preliminary replication are starting to trickle in.
https://www.tomshardware.com/news/superconductor-breakthrough-replicated-twiceNot a reputable source, but I'm gonna stay tuned
Important to note, the simulation results say nothing about the ambient pressure part of the claim (other than to quote it). And the other replication mentioned in that article is the replication of the manufacturing process. Taking all of these as true, we still wouldn't have replication of the most interesting part of the claim: a high Tc superconductor at ambient pressure.
  • #33
Tom's Hardware is not a reputable source? How dare you!
  • Haha
Likes DennisN and DaveC426913
  • #34
I do not consider a calculation, no matter how good, as experimental replication.
Likes DennisN and Borg
  • #35
Wikipedia has a table
Group by group as of now:
* Diamagnetism seen, waiting for resistance measurements
* No diamagnetism, high resistance
* Big changes in resistance as function of temperature, but low or no resistance only at 110 K. No Meissner effect.
* No diamagnetism seen
* Resistance doesn't drop to zero in measured temperature range
* No clear results yet
Just one group seeing diamagnetism is a bad start. Superconductivity implies (ideal) diamagnetism but the reverse is not true - even if the material is strongly diamagnetic it doesn't have to be a superconductor.
  • #37
Another thibg to have ib mind is that even if we find a RT SC at 1 atm, it doesn't necessailty make it useful. Not only because of the ability to make wires but also due to I max. It is said that if such a cuprate was found, it would be of little use, due to low I max. It may not lead to any technological revolution. Not sure this would be worth a nobel prize.
  • #38
That may be true for electrical and transport applications, but it could well be a benefit to information processing or instrumentation.
  • #39
Except in the dictionary, confirmation comes before application.
  • #40
I can make it consistent, by reverse sorting the dictionary, which would help to get an earlier retraction.
  • #41
Here's another thing that bugs me "LK"? Really? They named it after themselves? Not only is it worth 20 points on the Baez Index, do they not remember the GFAJ-1 fiasco?
  • #42
Fiasco normally comes before redaction and retraction.
  • #43
I don't think the arsenic crowd ever retracted. However, I think it has been generally accepted as wrong. "Too good to check" is a common problem with such papers.
  • #44
Worked (possibly) for J/Psi.
As far as I understand they picked that name as students and at a time they didn't expect that material to get larger attention.
  • #45
Smells like... uh, ... "but" ?
  • #46
Is it dead or does it still just smell funny?
We successfully synthesized polycrystalline LK-99-like ceramic samples with a solid-state-sintering method. Powder X-ray diffraction shows that the main contents are Pb10−xCux(PO4)6O and Cu2S, consistent with recent reports [arXiv:2307.12037; arXiv:2308.01192]. In some small flaky fragments, we successfully observed ``half levitation'' atop a Nd2Fe14B magnet. Using magnetization measurements on such small pieces, as well as on a large piece which does not exhibit the half levitation, we show that the samples ubiquitously contain weak yet definitive soft ferromagnetic components. We argue that, together with the pronounced shape anisotropy of the small fragments, the soft ferromagnetism is sufficient to explain the observed half levitation in strong vertical magnetic fields. Our measurements do not indicate the presence of the Meissner effect, nor zero resistance, in our samples, leading us to believe that our samples do not exhibit superconductivity.
https://arxiv.org/abs/2308.03110
Likes Lord Jestocost
  • #48
Is there any result that cannot be explained by this material being a diamagnetic metal?
  • #49
Nature: LK-99 isn’t a superconductor — how science sleuths solved the mystery
Instead, studies have shown that impurities in the material — in particular, copper sulfide — were responsible for the sharp drops in electrical resistivity and partial levitation over a magnet, which looked similar to properties exhibited by superconductors.
Multiple groups reproduced the claimed "levitation" with ferromagnetic elements and the sudden resistance drop seems to come from copper sulfide undergoing a phase transition.
Likes Filip Larsen, berkeman and Borg
  • #50
University of Nottingham physicist Philip Moriarty doesn't hold back about the way this initially unfolded
  • Love
Likes russ_watters, Lord Jestocost and DaveE
