Rotation of a magnetic computer disk
8 replies · 22K views
ada15
Hey guys, does anyone know how to approach these two problems ... can u please help me ?
Question 1. A magnetic computer disk 8.0 am in diameter is initially at rest. A small dot is painted on the edge of the disk. The disk accelerates at 600 rad/s2 for ½ s, then coasts at a steady angular velocity for another ½ s. What is the speed of the dot at t=1.0 s ? Through how many revolutions has it turned?
Question 2. A 300 g ball and a 600 g ball are connected by a 40-cm-long massless, rigid rod. The structure rotates about its center of mass at 100rpm. What is the rotational kinetic energy ?
I'll be really really thankful if you guys tell me how to approach these problems step by step.
Welcome to the PF, ada15. First of all, do not double-post your questions. I deleted your duplicate thread in the Advanced Physics forum.
Second, you must show some of your own work in order to get our help. How would you start question -1- ?
I have a similar problem to this. The numbers are slightly different, though.
A 260 g ball and a 510 g ball are connected by a 37.0-cm-long massless, rigid rod. The structure rotates about its center of mass at 140 rpm.
What is its rotational kinetic energy?
Well, I know I will need to find the center of mass first.
((.260kg)(0m) + (.510kg)(.37m))/(.26kg + .51kg) = .245 m
Knowing the center of mass, then I can find I
I= (m1)(r1^2)+(m2)(r2^2)
I=(.269kg)(-.245^2)+(.510kg)((.37-.245)^2)= .024 kgm^2
Now, I am not sure where I need to go from here.
Samurai Weck said:
KE= (1/2)mv^2
That's translational KE. What's the corresponding formula for rotational KE?
Samurai Weck said:
KE= (1/2)mv^2
That's the kinetic energy for linear motion. What is it for rotational motion? Hint -- just as mass comes into play for linear KE, the "moment of inertia" comes into play for rotational KE...
Ooooooh. K=(1/2)Iw^2
w(omega) = 140rpm(1min/60sec)(2pi/rotation)=14.66 rad/s
Krot= (1/2)(.024kgm^2)(14.66 rad/s)^2 = 2.53 J
Thanks A LOT. This was the one problem out of my homework that was kicking my behind.
