Rotational Collision: Mass, Radius & KE Lost
The discussion focuses on the rotational dynamics of two disks, where a disk of mass M1 = 350 g and radius R1 = 10 cm, rotating at an initial speed of 152 rpm, has a second disk of mass M2 = 247 g and radius R2 = 5 cm dropped onto it. The final common rotational speed, f(final), is calculated to be 129.2 rpm. Participants clarify the calculation of kinetic energy (KE) lost due to friction, emphasizing the need to use the common angular velocity for both disks and the correct moment of inertia formula, I = 1/2 M R^2, for accurate KE calculations.
  • Understanding of rotational motion and angular velocity
  • Knowledge of kinetic energy calculations in rotational systems
  • Familiarity with the moment of inertia for disks
  • Ability to convert between rpm and radians per second
  • Learn about the conservation of angular momentum in rotational systems
  • Study the effects of friction on rotational motion
  • Explore advanced kinetic energy calculations for composite systems
  • Investigate real-world applications of rotational dynamics in engineering
Physics students, mechanical engineers, and anyone interested in understanding the principles of rotational dynamics and energy loss due to friction in multi-body systems.
huskydc
A disk of mass M1 = 350 g and radius R1 = 10 cm rotates about its symmetry axis at finitial = 152 rpm. A second disk of mass M2 = 247 g and radius R2 = 5 cm, initially not rotating, is dropped on top of the first. Frictional forces act to bring the two disks to a common rotational speed f(final).
I already found f(final) to 129.2 rpm.
next the problem ask for the amount of Kinetic energy lost due to friction.
so i subtract initial KE from final KE to get the change in KE.
did i approach this wrong? b/c i kept getting the wrong answers...and all the numbers i got were pretty big...
Looks OK. Show how you calculated the KE.
The two masses rotate, when in final contact, at different angular velocities.
You didn't use the same (common) angular velocity for both , did you?
but it says that friction brings the two disks to a common rotational speed final. shouldn't i be using the same though?
For the final KE, of course you should use a common rotational speed (which you've already calculated). And for the initial KE, you would use the given initial rotational speed.
Again: How did you calculate the rotational KE of the disks? (Be sure to use \omega in radians/sec, not rpm.)
hold on...it says it's rotating about its symmetry axis, doesn't that make I = 3/2 m r^2?
anyways...if we assume I to be .5 m r^2, i calculate the KE like this:
KE initial = .5 I(1) omega(initial)^2 + .5 I(2) omega(initial)^2
= .5 [.5 m(1) r(1)^2] omega(initial)^2
= .25 m(1) r(1)^2 omega(initial)^2
KE final = .5 I(1) omega(final)^2 + .5 I(2) omega(final)^2
= .25 m(1) r(1)^2 omega(final)^2 + .25 m(1) r(1)^2 omega(final)^2
KE final - KE initial =...
convert rpm to rad/s...and plug in numbers...i get a range of different numbers, big to small..
No. For a disk, I = 1/2 M R^2.
Nothing wrong with this.
I assume you meant the second term to be for the second disk: m(2), r(2).
Looks OK to me. How can one method give you a range of answers?
OK, I think I figured this out.
When I first read this, I interpreted it as meaning that when the two disks came into contact then (kinetic) friction between the disks would start to rotate the disk M2 until the two disks had the same periferal velocity. (At which point rolling friction would take over.) Had that been the case, then ω2 = 2*ω1. I thought the "rotational" bit must be a typo!
Hiowever it seems that in addition to the kinetic friction between the disks, there is also some (internal) friction slowing disk2 down until ω2 = ω1.
My mistake - sorry 'bout that.
16K
