Rotational Dynamics - moment of inertia finding
The discussion focuses on calculating the net torque and angular acceleration of a seesaw with two children at opposite ends. The net torque was correctly calculated as 83.385 Nm, which equals Iα. To find the moment of inertia, it is necessary to consider the contributions from both children and the seesaw, treating the children as point masses and the seesaw as a thin rod. The correct formula for the total moment of inertia involves summing the individual contributions without any negative signs. The conversation emphasizes the importance of accurately applying the moment of inertia formula for each component involved.
pat666
2 children, masses 35kg and 40kg sit at opposite ends of a 3.4m seesaw with mass 25kg with the fulcrum at midpoint. with the seesaw horizontal find
a) the net torque
b)angular acceleration
tau=rF=Ialpha
i got the right answer for a ----83.385Nm which i know is equal to Ialpha. my problem is finding the moment of inertial i have tried mr^2 which i knew wouldn't work (tried it just to make sure) anyways i need some help
Actually mr^2 will work for part of the answer. To find the total moment of inertia, add up the contributions of each part: The two children plus the seesaw itself. Hint: Treat the children as point masses; treat the seesaw as a thin rod.
so for the the total moment of inertia: 40*1.7^2+-35*1.7^2+Irod?
Yes. (But get rid of that minus sign--I suspect it's just a typo.)
