Rotational Kinematics (String attached to disk)
mattj150
Determine the relationship between the angular
acceleration of the flywheel, the downward acceleration of the block, and the radius of
the ring.
Known data:
Mass Ring: 1.420 kg
Radius Ring (Inside, then Outside): 5.10 cm, 6.325 cm
Mass Disk: 1.455 kg
Radius Disk: 11.45 cm
Mass Shaft: Negligable
Radius Shaft: 0.6 cm
ω=ω0 + αt
f=ma
I'm really lost on this, i assume that i need to calculate the tension the block places on the string (F=MA)? Could anyone give me a hint on how to get started on this.
  • Diagram of a rotational apparatus: a flywheel disk on a vertical shaft mounted on a stand, with a string wound around its rim running over a pulley at the right end of a table to a hanging weight. A clamp is attached to the table edge.
Welcome to PF;
Your wish is my command:
hint: draw free-body diagrams.
Though you could use conservation of energy and assume acceleration is constant.
I understand how to do the FBD for the hanging mass. The forces acting on it are simply Fg and Ft. How would i do a FBD for the spinning mass? Would i pick a point on the outer edge to do it for?
The tension force acts at a particular location on the flywheel - creating a torque. ##\tau=I\alpha##
