Rotational kinetic energy decreases, internal increases?
4 replies · 2K views · last reply
Gian_ni
If rotational kinetic energy of a closed system decreases, another form of energy must increase for the conservation of energy of a closed system.
We assume this system (a person in rotation) has these forms of energy:
ΔE=ΔK (only rotational around an axis) + ΔUi (internal) + ΔEt (thermal) with ΔE=0, ΔK<0
The muscles make always an effort so also ΔUi<0. Then ΔEt>0 Is it right?
But if ΔK>0 the muscles make an effort ΔUi<0. ΔUi = -ΔK ( ΔEt=0 )
There is a contradiction in the first case so that ΔUi should be > 0 ?
Thank you
Muscles? Do you have some specific system in mind?
Probably. It is not clear what exactly you consider.
In general there will still be friction, and the muscles have to provide energy both for friction and for increasing the kinetic energy.
Biological systems are messy. When in doubt, choose a simpler system. Here, I would recommend a pair of masses attached to a spring of rest length L. You can see changes in KE and internal energy. Later, if you want to add changes in thermal energy you can make it a damped spring by adding a dash pot.
Yes, muscles of a person that change his moment of inertia..
So, if ΔK is <0 why isn't ΔUi>0 ? Certainly we know that if ΔK>0 ΔUi<0 ( the person has dissipated energy )
It would be, except that muscles do not harvest energy when they are expanded while under tension. If you run down a mountain side, it does not put glucose back into your bloodstream. The lost energy will almost certainly wind up as heat. Wasted energy usually does.
