Rudin Problem 2.7: Proving Closure of Unions
  • Thread starter Thread starter Mogarrr
    Analysis Proof
Mogarrr
Let A_1, A_2, A_2,... be subsets of a metric space.
(a) If B_{n}=\bigcup_{i=1}^{n}A_{i}, prove that \bar{B_{n}}= \bigcup_{i=1}^{n}\bar{A_{i}} for n=1,2,3,...
(b) If B=\bigcup_{i=1}^{\infty}A_{i}, prove that \bar{B} \subset \bigcup_{i=1}^{\infty}\bar{A_{i}},
Show by example this inclusion is proper.
[/B]
If E is a subset of a metric space, then the closure of E,
\bar{E}=E \bigcup \acute{E}, where \acute{E} is the set of all limit points of E.
For a subset E of a metric space X, a point p \in X is a limit point if and only if
\forall \epsilon > 0, \exists q \in B(p;\epsilon) \bigcap E : q \neq p
Now I think I've got part (a) and (b) nailed down, but I'm having trouble thinking of an example for a proper subset. Here's what I have thus far...
Suppose x \in \bar{B_{n}}, then x \in B_{n} or x is a limit point for B_{n}.
If x \in {B_{n}}, then x \in \bigcup_{i=1}^{n} A_{i}, then \exists i, x \in A_{i}, so \exists i, x \in \bar{A_{i}}.
If x is a limit point, then
\forall \epsilon > 0, \exists y \in B(x;\epsilon) \bigcap B_{n}: y \neq x, so \forall \epsilon > 0, \exists y \in B(x;\epsilon) \bigcap (\bigcup_{i=1}^{n} A_{i}): y \neq x, then
\exists i,\forall \epsilon > 0, \exists y \in B(x;\epsilon) \bigcap A_{i}: y \neq x, then
\exists i, x\in \bar{A_{i}}, so x \in \bigcup_{i=1}^{n}\bar{A_{i}}
Suppose x \in \bigcup_{i=1}^{n}\bar{A_{i}}, then \exists i, x \in A_{j} or for some i x is a limit point.
If \exists i, x \in A_{i}, then x \in \bigcup_{i=1}^{n}A_{i}=B_{n}.
If x is a limit point for some A sub i, then x is a limit point for \bigcup A_{i}=B_{n}.
For part (b), I did the same thing, but replaced B_{n} with B and in the union I replaced n with infinity.
Now, I'm having some difficulty coming up with an example that would show B is a proper subset of the union of an infinite number of A sub i's.
Any hints or corrections would be much appreciated.
[/B]
I can see a fixable flaw in your argument for (a). For simplicity, take ##n = 2##; that is not a loss of generality, since you can then get the general case of finite ##n## by induction.
Anyway, say ##x \in \bar{B}_2## is in the boundary of ##B_2## but not in ##B_2## itself. Let ##\epsilon_1 > \epsilon_2 > \cdots \to 0##. For ##\epsilon_i## there is a point ##x_i \in B_2 \cap N(x,\epsilon_i)##. It is conceivable that we could have, for example, ##x_1 \in \ A_1, x_2 \in A_2, x_3 \in A_1, x_4 \in A_2, \ldots## so the sequence ##\{x_i\}## is not in a single set ##A_1## or ##A_2##, but, instead, oscillates back and forth between the two. In that case you would need to do more work to conclude that ##x## is in ##\bar{A}_1 \cup \bar{A}_2##. It can be done, but some extra steps are needed; I think the fact that you are working an a metric space matters a lot here.
[/B]
Are you sure the inclusion in part (b) is the right way round? Certainly one can show by example that <br /> \bigcup_{i=1}^\infty \bar{A}_i \subsetneq \bar{B} by taking a bijection f : \{1, 2, 3, \dots \} \to \mathbb{Q} (such a bijection exists because the rationals are countable) and setting A_i = \{f(i)\} \subset \mathbb{R}.
So what you're saying is that just because \forall \epsilon &gt;0,\exists y \in N(x;\epsilon) \bigcap \bigcup_{i=1}^{n} A_{i}, I can't conclude that \exists i, \forall \epsilon &gt;0,\exists y \in N(x;\epsilon) \bigcap A_{i}?
Would I have to say that for a sequence of epsilons, there is a y in the intersection of the Neighborhood with center x and radius epsilon? I thought about distributing the intersection/union, but that doesn't make much sense to me, intuitively.
pasmith,
Wow, really nice example. Am I correct in saying "because each of the singletons have no limit points, the union of the A sub i's are the rationals, but the closure of B is the reals"?
And yes, I was wrong. It should be...
Show by an example, that this inclusion B \supset \bigcup_{i=1}^{\infty} A_{i} can be proper.
Mogarrr said:
pasmith,
The point is not that a singleton has no limit points, but that it contains its only limit point and is therefore closed, so that \bigcup A_i = \bigcup \bar{A}_i. Otherwise you are correct, although you need to explain briefly why \bigcup_{i=1}^\infty \{f(i)\} = \mathbb{Q}.
Likes Mogarrr
You probably can conclude it, but it does not follow right away from what you did; you need some extra steps.
