Running Windows programs on Mac: dual boot or virtual machine?
31 replies · 5K views
dRic2
I need windows on my mac to run some modeling programs, but I'm not sure whether go for dual boot or virtual desktop. I have all my programs already installed and I fear that dual boot + installing all the programs again will suck too much memory space... on the other hand I have never enjoyed the idea of virtual machines.
Any suggestion?
Thanks
RIc
Ram space would be unaffected by dual boot. Can you buy and install a second hard drive into the Mac and install windows on the second drive?
Thanks, but I've never done that, I'm going to look it up on google.
Otherwise I could sell my mac and buy a new pc... :olduhh:
You’re better off having separate machines running in parallel instead of dual booting especially between Mac and windows. Filesharing becomes an issue with respect to text files the lf vs crlf line termination as well as other things.
Well I'd like not to buy an other computer. If that is the case, then I'll probably have to sell my mac
Windows machines are pretty cheap relative to what you paid for the Mac. Also the Mac has a unix-based OS and in the ling run for software development, its a better platform especially if you also need to develop for Linux too.
That's way I saved up money and I bought one... and it took me quite a long time too. Plus I had like 200 Euros of discount. If I buy a windows pc only to run this program it will be, to me, just a waste of money, and I can't afford to spend 700/800E for a windows pc with very high specs.
I'll see what I can do
What modeling program are you using? Blender and Maya both run on Mac, I do plenty of 3D modeling and it's all done on my Mac. Even if it's Windows-only, it's entirely possible you could simply run it as-is through Darwine. I have many Windows-only programs running on my Mac through Darwine wrappers.
I use Virtualbox on my Mac with a Windows 10 VM. It works very well but needs quite a lot of RAM for the VM not to impact on Mac OS X too much. I wouldn't use the Windows VM for doing much modelling work though. If I need to do that I use a Windows box and use remote desktop to it.
Cheers
Hi, I think modeling is the wrong word (I apologize). Basically I have to run this program, written in c++, to simulate the behavior of a flame. It's just lots of calculations, nothing special. I'd like to use MATLAB and excel too (that I've installed on my mac). It's written by my professor and I think it is windows only since it runs a .bat file and use the command prompt as main window.
I've a macbook air
I've a macbook air
Is it all DOS? you can look at the .bat file with a text editor, to see what it does.
The program is actually very easy. I've to write some text files with all the properties I want and the right algorithms and then give them to it. It's like a compiler
Running the program under a virtual Windows is probably the best approach, unless the program is very resource intensive.
If it is very resource intensive, it could be still better to increase memory on your one machine.
A second PC to run one program is a technically more efficient solution, but could be unnecessarily more expensive .
Dual boot is a possibility, but freqently rebooting could get painful.
If it’s written in c/c++ then you might be able to recompile and run it on your Mac. The gotcha would be if your prof used windows specific apis or windows GUI.
However, if it simply computes and writes to the screen or a file then there’s a good chance it can easily be rebuilt on Mac.
it depends on what I have to do. For now it seems a light program, but maybe next year things will get harder. I think I'm going to go for virtual windows and see how it handles it. By the way I have one more question about virtual machines. I really need to copy the output files of this program in MATLAB and excel so I was wondering: is file sharing easy on virtual machines?
Unfortunately I think so, because when I tried it on a friend pc I had to change some Windows Environment Variables
You can make a partition on your hard disk which is there for shared data.
Not what I would call easy, but doable.
You mean a real partition? Or a virtual one? This is not a good news... :(
An actual disk partition on your hard drive which physically exists and is accessible from whatever OS is looking.
Or a separate disk drive just for the shared data. most PCs (not laptops} will accept two physical drives.
Not as expensive a whole new PC, but going that way
scottdave said:
It seems my post didn't go through earlier. Have you inspected the BAT file with a text editor to see what it does?
Oh I'm very sorry. The .bat file just calls an .exe file.
scottdave said:
Is there a lot to it?
The main problem of virtual machines is that I will have to install Matlab and Excel again on virtual Windows (I will lose memory for nothing) or I need some way to share the output file from virtual Windows to Matlab and Excel on my mac. I don't know if there is an easy way to do that
I was mentioning earlier that you could make a disk partition or even install a second disk drive for shared data.
Now I think I have a better idea.
You could get one of those cheap USB memory sticks. use that for shared data.
If both OS's can see the memory stick it could work (I think).
Yes, and find out what exactly the requirements are for this simulation program is. Maybe you do not need all of Windows for it to run
I'll give it a try. Thanks for all the good suggestions :)
