Rust in test-tubes of HCl FeO or Fe3O4?
  • Thread starter Thread starter prime-factor
    Hcl Rust
The discussion focuses on the formation of rust in steel nails submerged in hydrochloric acid (HCl) solutions with a pH of 1.5 to 2. The black rust observed, which settles at the bottom of the test-tube, is identified as FeO, while the red rust formed in salt solutions is attributed to Fe2O3. The difference in rust color and attachment to the nails is explained through the presence of Fe2+ ions in HCl, which do not oxidize to Fe3+ as quickly as in saline solutions. This highlights the role of coordination inorganic chemistry and Crystal Field Theory in understanding these reactions.
  • Basic understanding of rust formation and iron oxidation states
  • Familiarity with hydrochloric acid (HCl) and its properties
  • Knowledge of coordination chemistry and Crystal Field Theory
  • Experience with laboratory experiments involving chemical reactions
  • Study the principles of Crystal Field Theory in coordination chemistry
  • Research the oxidation states of iron and their implications in rust formation
  • Explore the effects of pH on metal corrosion and rusting processes
  • Investigate the differences between FeO and Fe2O3 in terms of chemical properties and applications
Chemistry students, materials scientists, and anyone interested in the chemical processes of corrosion and rust formation in metals.
prime-factor
rust in test-tubes of HCl FeO or Fe3O4??
I am doing experiments on steel nails in HCl solutions with a pH of about 1.5 - 2.
The rust is black in colour, and is not attached to the surface of the nails. It stays at the bottom of the test-tube. Is this FeO or Fe3O4. Why is it that the rust I am getting in solutions of just salt is not the same colour?. And why is it red and attaching to the nail?
Chemistry news on Phys.org
It has a lot to do with coordination inorganic chemistry which depends on quantum mechanical explanations which relate the iron to the " field " of ligands around it to explain the color , you may want to start off with Crystal Field Theory.
Maybe with HCl you get more Fe2+ ions, that don't have enough time to be oxidized by air oxygen into Fe3+. In the first case you would get FeO (black), in the second Fe2O3 (red).
  • · Replies 21 ·
34K
9K
28K
  • · Replies 56 ·
54K
