Safe removal of an external disk
  • Thread starter mech-eng
    Disk
17 replies · 3K views · last reply
mech-eng
When we cannot safely remove our usb memories and disks what are the other options? Sometimes we cannot safely remove them and take a notification. According to that notification a program is using the drive so we cannot remove it at that moment. Do you know what the error code for this situation? And is removing the drive from device manager a safe option?
Windows Device Manager tree showing Disk drives expanded, with Hitachi HTS543232L9A300 and Mass Storage Device USB Device listed, and a context menu open with Update Driver Software, Disable, Uninstall, Scan for hardware changes and Properties.
  • Windows Device Manager tree showing Disk drives expanded, with Hitachi HTS543232L9A300 and Mass Storage Device USB Device listed, and a context menu open with Update Driver Software, Disable, Uninstall, Scan for hardware changes and Properties.
Try logging off, then log back in and quickly try to "stop" the external device.
I tried that but it didn't work. There were more options sometimes but that time I didn't see it. Sometimes when right clicking under my computer, there are three options, one of them stops the drive even though a program use it, but that time I didn't see it. So what about my idea of use of device manager? Is it safe? I am afraid for my disk's file system again turn into RAW file system. Unsafe removal is one of the reasons of RAW file system.
Thank you.
The only time you really need to worry is when you’re writing to the device. If you mount it to retrieve a file then it’s okay but not a good practic.
Programs that can make the device busy are a command line session that points to a directory on the device. I’ve gotten this from time to time. The other case is an installer that you haven’t exited from which is using the device or a file explorer utility like windows explorer or Apples finder.
In the case of Windows, last access time does a write to the drive even when just reading a file. To stop that, open administrator DOS console window or use "Run" as administrator. Enter the following command:
fsutil behavior set disablelastaccess 1
to check the current setting use:
fsutil behavior query disablelastaccess
This works for Windows XP, Windows 7, Windows 10, and should work for Windows Vista and Windows 8 (I don't have Vista or 8 and can't check).
I checked this on my Windows 10 PC and it was set to 1. I have never changed it, so the default may now be 1.
mech-eng said:
When we cannot safely remove our usb memories and disks what are the other options? Sometimes we cannot safely remove them and take a notification. According to that notification a program is using the drive so we cannot remove it at that moment. Do you know what the error code for this situation? And is removing the drive from device manager a safe option? View attachment 219402
I don't believe there is an error code associated with that. The device is obviously still in use - being read from and/or written to. You need to wait a while and attempt to safely remove the USB (or whatever) again.
No. It is not. I have the same issue (frequently) with a USB drive and on occasion I have waited for many hours and in one case even a couple of days, and the device continues to register as "in use" even though it very obviously is not. I just unplug it and have never had any ill effects. I DO always wait for at least 10 minutes or so after my last access of the device.
Svein said:
Right-click on the device and select "Eject".
When the system thinks an external drive is in use, the eject fails.
Me too.
That's right...
Look at the drives "Policies" ... maybe you can just disconnect it ?
Windows Device Manager Disk drives list with Seagate FreeAgent USB Device selected, and its Properties dialog open on the Policies tab showing Quick removal (default) selected over Better performance.
  • Windows Device Manager Disk drives list with Seagate FreeAgent USB Device selected, and its Properties dialog open on the Policies tab showing Quick removal (default) selected over Better performance.
Ah, I see. I should correct my post to relay that the device may, according to the OS, is still in use but is not.
Many hours?! Good grief!
Yes. Once it goes wrong, it will never correct itself. I haven't done a scientific study, but is seems as though some external disks cause more frequent trouble than others.
Shutdown computer or Restart. While the computer is OFF, remove the device.
Seriously not necessary. See post #9
My worry is that I am never sure that some Windows utility is not doing something (scanning or cleaning up). I assume that they do not do that to external drives, but it still worries me. When in doubt, I watch the disk usage in the Task Manager/Performance to make sure that nothing is hitting the drive. If nothing is going on, I pull the drive.
There is a free utility I've found quite useful over the years. It reports every open file on the system, what program has opened it, and it even sorts the results by Drive. Right now it reports there are 615 files open, spread across 15 logical drives. (Windows is absolutely INSANE!)
http://www.nirsoft.net/utils/opened_files_view.html
