- 4,276
Momentum is different from energy here. See also this thread:sophiecentaur said:Momentum is conserved so you have to be right in principle. But doesn't that approach close the door on all simple momentum questions that we started our Physics education? The Earth is 'big enough' ...
https://www.physicsforums.com/threa...vs-momentum-conservation.1059279/post-6989294
The Earth is never 'big enough' to neglect the momentum it receives, and still have momentum conserved, on the scale of the much smaller object's momentum change. Not even in the Earth's initial rest frame you can get away with that.
The Earth is 'big enough' to neglect the energy it receives in its initial rest frame, and still have energy approximately conserved in that frame, because in that frame the work done on the Earth is negligible, compared to the work done on the much smaller object.
But in frames where the Earth is moving, the work done on the Earth is not negligible, compared to the work done on the much smaller object. See for example my question about the Brennan torpedo:
A.T. said:![]()
And here is a question to ponder: In case A2 (rest frame of the cable), since the motor cannot power the torpedo via a static cable, where does the energy from the motor go to?
