Santa's Sleigh (Newton's 2nd Law-1D) Acceleration, Horizontal Motion
The discussion revolves around a physics problem involving Santa's sleigh, focusing on Newton's 2nd Law and concepts of acceleration and horizontal motion. The problem presents a scenario where the sleigh, with a specified mass, is pulled by reindeer with a given average force over a distance before takeoff.
  • Mixed
  • Participants explore the application of Newton's 2nd Law, questioning the use of average acceleration and the implications of the average force provided. There are discussions about the clarity of the problem statement, particularly regarding the total force exerted by the reindeer and the absence of Santa in the sleigh.
Participants are actively questioning the assumptions and definitions in the problem, particularly regarding the average force and its implications for acceleration. Some suggest that the problem may require the application of work and energy concepts, while others express uncertainty about the information provided and its sufficiency for solving the problem.
There is a noted lack of clarity in the problem statement regarding the nature of the force exerted by the reindeer, leading to discussions about whether it is a constant force or varies over time. Participants highlight that without additional information, the problem may not be solvable as presented.
Angelx26
Santa's sleigh, which has a mass of 62.5 kg (without Santa as an occupant), is pulled by eight tiny reindeer with an
average force of 8350 N over a 60.0-m stretch of snow before becoming airborne. Assuming the sleigh started
from rest, what was the sleigh's takeoff speed? (Ignore friction).
I am using a study guide that doesn't show much work, only shows the answers. I know it involves Newton's 2nd Law.
F=ma.
All I know is that it involves Newton's 2nd law F=ma.
Im wondering if I use average acceleration (vf-vi)/time
I'm not sure where else to go from here.
Angelx26 said:
Homework Statement: Santa's sleigh, which has a mass of 62.5 kg (without Santa as an occupant), is pulled by eight tiny reindeer with an
Homework Equations: F=ma.
Do you think each reindeer pulls with a force of 8350N, or is that the total? It's not clear to me what is meant.
Where is Santa? Why isn't he in his sleigh? That's another puzzle.
And, yes, you can take ##F_{avg} = ma_{avg}##
Since the reindeer pull with an average force, then that implies an average acceleration, to me.
One moment while we wait for @haruspex to call attention to the blunder in the problem statement...
The problem setter is begging for you to apply the concepts of work and energy here.
Yes, but without knowing the duration that does not help.
Thanks for the invitation... you know I can't resist.
@Angelx26 , sadly there is not enough information to answer the question. Had you been told it was a constant force then there would have been several ways to solve it, e.g. using work=force x distance, or F=ma together with v2-u2=2as. The two are essentially the same.
As it is, it depends how the force varies with time. E.g. if no force at all for 9 seconds then 83500N for one second then work = 83500N x 60m = ½mv2, but if a constant force then work is only 8350N x 60m.
I agree that the question should have been stated clearer. My best guess is that by the "average force" of ##8350\text{ N}## it is meant that the total force exerted by the eight tiny reindeer at every moment is ##8350\text{ N}##, i.e. the sleigh is pulled by a constant force of ##8350\text{ N}##. As was discussed, if the force varies with time the given information is incomplete and ##8350\text{ N}## per reindeer is probably too much, even for Santa's reindeer.
So I'd just solve it for the simplest case of a constant force, but yeah, the wording is somewhat murky.
I guess the word "average" is often used in these problems because a constant force sounds unrealistic, so the intended assumption is that the force stays close to a certain value, with some relatively small variation. This would support a further simplifying assumption that the force is constant for the purpose of calculation.
A better statement would be to assume that the force is approximately constant.
  • · Replies 42 ·
