Scaled Particle Theory: Rigid Spheres Equation of State
  • Context: Graduate
  • Thread starter Thread starter itaischles
    Particle Theory
The discussion centers on the equation of state for rigid spheres as presented in the article "statistical mechanics of rigid spheres" by Reiss, Frisch, and Lebowitz (1959). Participants explore the implications of the probability functions defined in the article, particularly the normalization of these functions and the nature of the work function, W(λ), used in the calculations.
  • Some participants question the normalization of the probability function p0(λ) = e^(-W(λ)/kT), arguing that without knowing W(λ), it is unclear why p0(λ) should be normalized.
  • Others suggest that a work function W(λ) proportional to the surface area (λ²) could yield a monotonically decreasing p0(λ), but integrating this over all λ does not necessarily result in a normalization to 1.
  • There is a discussion about the conditional probability of finding a molecular center in the shell [λ, λ + dλ], expressed as 4πλ²ρG(λ)dλ, with some participants noting that this expression also lacks normalization under certain conditions, such as when G(λ) = 1 for an ideal gas.
  • Some participants express uncertainty about whether the authors provide constraints or specific forms for W(λ) in the article, with references to other papers that derive functions for W and G.
  • It is noted that the theory does not aim to derive W(λ) but rather uses a given W(λ) to calculate other properties, leading to questions about the assumptions made regarding W(λ).
Participants generally express disagreement regarding the normalization of the probability functions and the implications of the work function W(λ). There is no consensus on whether the authors adequately address these issues in their article.
Participants highlight that the normalization of p0(λ) depends on the choice of W(λ), which remains unspecified in the article. The implications of this choice on the overall model are not resolved, leaving open questions about the assumptions underlying the theory.
itaischles
Hi all,
I'm reading an article titled "statistical mechanics of rigid spheres" by Reiss, Frisch and Lebowitz (1959). It tries to capture the equation of state of rigid spheres.
In their article they write the probability that at a random point in the fluid the center of the nearest molecule is a distance ##\lambda ## away and in the range ##[\lambda,\lambda+d\lambda]##. They separate this probability to the product of the probability of finding a cavity of radius ##\lambda##, denoted ##p_0(\lambda)## times the conditional probability of finding at least one molecular center in the ##[\lambda,\lambda+d\lambda]## shell given that there is a cavity of radius ##\lambda## there. So far so good.
My problem is that they assign things that doesn't look like probabilities to the two product terms. First, they claim that ##p_0(\lambda)=e^{-W(\lambda)/kT}## where ##W(\lambda)## is the reversible work needed to create the cavity. Since we don't know anything about this ##W(\lambda)## why do we assume that ##p_0(\lambda)## is normalized? Then they say that the conditional probability of finding at least one molecular center in the ##[\lambda,\lambda+d\lambda]## shell is ##4\pi \lambda^2 \rho G(\lambda) d\lambda## where ##\rho## is the average fluid density and ##G(\lambda)## is the radial distribution function at the cavity's surface. This too is not normalized since if we look for example at an ideal gas (where ##G(\lambda)=1##) and integrate over ##\lambda## between 0 and ##\infty## we get ##\rho V=N## where ##V## is the volume and ##N## the number of particles in the system. Can anybody comment on that please? Thanks!
Can you find a possible ##W(\lambda)## where ##p_0(\lambda)## is not normalized?
Isn't ##\rho## the particle number density?
Regarding the first reply: let us take, for example, a work function ##W(\lambda)## that goes like the surface area of the sphere ##\lambda^2##. It is reasonable since the work needed to create a cavity of size 0 is 0 and it monotonically increases as ##\lambda## get's bigger, "exploding" at infinity. Then ##p_0(\lambda)## is monotonically decreasing, starting at 1 (when ##\lambda=0##) and reaching 0 at infinity. Integrating this over the range ##0<\lambda<\infty## gives some number, not necessarily 1.
Regarding the second comment, ##\rho## is, indeed, the particle number density, as I have written. Is there anything I miss here?
itaischles said:
Regarding the first reply: let us take, for example, a work function W(λ)W(\lambda) that goes like the surface area of the sphere λ2\lambda^2. It is reasonable since the work needed to create a cavity of size 0 is 0 and it monotonically increases as λ\lambda get's bigger, "exploding" at infinity. Then p0(λ)p_0(\lambda) is monotonically decreasing, starting at 1 (when λ=0\lambda=0) and reaching 0 at infinity. Integrating this over the range 0<λ<∞0
OK - so what does the paper say about W? (You may have to read between the lines.)
Is there an online copy of the paper I can see?
itaischles said:
Regarding the second comment, ρ is, indeed, the particle number density, as I have written. Is there anything I miss here?
Well you wrote:
itaischles said:
This too is not normalized since if we look for example at an ideal gas (where G(λ)=1G(\lambda)=1) and integrate over λ\lambda between 0 and ##\infty## we get ρV=N where V is the volume and N the number of particles in the system.
... so what is wrong with that?
It may be that you are expected to realize that the function should be chosen so that the result is normalized - they are building a model.
Did you read the rest of the paper to see what they came up with?
There it is: ftp://213.176.96.142/aip1c48329b-957e-20141114083409.pdf
or: http://scitation.aip.org/content/aip/journal/jcp/31/2/10.1063/1.1730361
Well, for [itex]p_0(\lambda)[/itex] to be a probability function, it has to be normalized so when you integrate over all possible values of [itex]\lambda[/itex] you get 1. Here we get some number which depends on your choice of [itex]W(\lambda)[/itex]. In their article they don't say anything special about [itex]W(\lambda)[/itex] except for the fact that it is the reversible work needed to create the cavity. It could equally be volume work, surface work... whatever.
I did read the rest of the paper but still, no sign of any constraints on [itex]W(\lambda)[/itex].
It looks like it comes ut in the wash though - other papers running the same thing end up deriving functions for W and G.
Do the authors not do anything like that here?
The theory isn't about deriving the W function as far as I understand it. It uses a given W function to calculate all other things so it can't assume anything about it, besides the fact that it should go to [itex]\infty[/itex] when [itex]\lambda\rightarrow\infty[/itex] and to 0 when [itex]\lambda\rightarrow0[/itex].
As I understand it, other papers do the same thing only with explicit W functions as opposed to this article.
