Scattering force in optical trapping
The discussion centers on the origins of the scattering force in optical trapping, highlighting its dependence on both reflection and refraction of light by dielectric objects. It clarifies that the scattering force arises from the interaction of incoming rays with the particle, with contributions from both specular reflection and refracted rays. In the ray optics regime, the net force on a microsphere is analyzed by considering these contributions, leading to a distinction between scattering force and gradient force. The relationship between incident angle and the ratio of gradient to scattering force is also noted, indicating that larger angles yield a higher ratio. Overall, the explanation aligns with established theoretical frameworks in optical trapping.
pen
hello,
reading about the theoretical background of optical trapping. I was wondering how the scattering force originates. Often it is written, that the scattering force is due to reflection, but also the central rays refracted by a dielectric object should contribute ? So the scattering force is due to specular reflection of the incoming rays and refraction of the central rays ?
thanks.
Science news on Phys.org
thanks a lot! now I think:
in the ray optics regime:
The net force exerted on a microsphere by one ray is calculated considering the contribution of forces due to reflection and due to refraction, (depending on the incident angle of the ray).
The net force can be decomposed into scattering (defined as parallel to the incident ray) and the gradient force (defined as perpendicular to the incident ray).
A ray of large incident angles (with respect to the optical axis) has a higher ratio of gradient force/scattering force.
hope it`s not that wrong ?
21K
23K
