How Does an Electron Behave in a 1D Crystal Potential Well?
The discussion centers on the behavior of an electron in a one-dimensional crystal potential well defined by the potential function U(x) = \frac{-\overline{h}^{2}x^{2}}{mL^{2}(L^{2}-x^{2})} for |x| < L. Participants confirm that the proposed wave function ψ(x) = A(1 - \frac{x^{2}}{L^{2}}) satisfies Schrödinger's Equation under specific conditions, leading to the energy value E = \frac{\overline{h}^{2}}{mL^{2}}. The conversation emphasizes the importance of ensuring that the solution is valid for all x within the defined range, not just at a single point.
  • Understanding of Schrödinger's Equation
  • Familiarity with potential wells in quantum mechanics
  • Knowledge of wave functions and their properties
  • Basic calculus for differentiation and solving equations
  • Study the implications of negative potential energy in quantum mechanics
  • Learn about normalization of wave functions in quantum systems
  • Explore the concept of stationary states and their significance
  • Investigate other potential well scenarios, such as finite and infinite wells
Students and researchers in quantum mechanics, particularly those studying wave functions, potential wells, and the application of Schrödinger's Equation in one-dimensional systems.
wavingerwin
An electron in a one dimensional crystal is bound by:
U(x) = \frac{-\overline{h}^{2}x^{2}}{mL^{2}\left(L^{2}-x^{2}\right)}
for
\left|x\right| &lt; L
and
x = infinity
for
\left|x\right| \geq L
Show that a stationary state for the electron in the potential well
\psi(x) = A\left(1-\frac{x^{2}}{L^{2}}\right)
satisfies the Schrödinger's Equation
and find E
\frac{-\overline{h}^{2}}{2m}\frac{d^{2}\psi}{dx^{2}}+U(x)\psi = E\psi
from Schrödinger's:
\frac{d^{2}\psi}{dx^{2}} = \frac{-2m}{\overline{h}^{2}}\left(\frac{\overline{h}^{2}x^{2}}{mL^{2}\left(L^{2}-x^{2}\right)}+E\right)\psi
and from the guess solution:
\frac{d^{2}\psi}{dx^{2}} = \frac{-2A}{L^{2}} = \frac{-2}{\left(L^{2}-x^{2}\right)}\psi
and so equating \frac{d^{2}\psi}{dx^{2}},
I deduced that it satisfies the Schrödinger's equation but only when E = 0 and x = L.
Am I right?
I am also concerned because the potential, U, is negative 'inside' the well...
It can't be a stationary state if it only satisfies the Schrödinger eqn at a single 'x' point. I think you need to double check your work on this problem, since you made an incorrect assumption.
I suggest simplifying the two terms you list in the parenthesis of the first eqn in your attempt at a solution. Convert it to one giant fraction. Then try to find an energy that will remove the 'x'-dependence in the numerator of that fraction. You will want to keep the x-dependence in the denominator since it needs to equal your 2nd equation. You want this equality to be applied to any value of 'x' and not just one specific value like before.
Hi nickjer
After putting it as a single fraction, I got:
<br /> \frac{d^{2}\psi}{dx^{2}} = \left(\frac{-2}{\left(L^{2}-x^{2}\right)}\frac{x^{2}\left(\overline{h}^{2}-mE\right)+mL^{4}E}{L^{2}\overline{h}^{2}}\right)\psi<br />
I just cannot figure out how to remove the x dependencies in the numerator.
If I equate this with
<br /> \frac{d^{2}\psi}{dx^{2}} = \frac{-2}{\left(L^{2}-x^{2}\right)}\psi<br />
I can get a value for E, however it depends on x, which i think is wrong...
Maybe, just maybe, is the question wrong and
<br /> \psi(x) = A\left(1-\frac{x^{2}}{L^{2}}\right)<br />
is not a possible solution to the situation?
Double check your math for the numerator. I believe you are missing something. Also, once you correct the numerator, then you see the x^2 has a coefficient next to it in parenthesis. Very similar to what you have now (although yours is slightly wrong). Since you are solving for the energy that makes this stationary state satisfy Schrödinger's eqn, then you are free to choose an E that will make this coefficient in parenthesis go to 0. Then you will have 0*x^2 = 0. So you canceled out the x-dependence.
If I'm right this time, I was missing L2
And so I equate 0 = hbar2 - L2mE
and also, after eliminating x2, I equate to the guess solution,
and both of them give me a consistent answer:
Now, I think this is right!
If it is, thanks very much :smile:
  • · Replies 0 ·
  • · Replies 20 ·
