Schwartzschild metric difficulty
  • Level: Graduate
  • Thread starter Thread starter Thinkor
    Difficulty Metric
Thinkor
I am trying to understand how the Schwartzschild metric works and coming to the conclusion that if I drop an object that it will not fall to the Earth but just stay there when I open my hand. Therefore, I'm confident I have made a mistake, but I don't see where it is.
Here is the metric directly from Schwartzschild's paper. This agrees with various other sources I've seen although the notation is different.
ds2 = (1 - α/R)dt2 - dR2/(1 -α/R) - R2(dθ2 + sin2θ d∅)
where α is the Schwartzschild radius, t is the time coordinate, and R is the radial coordinate. Please note that Schwarzschild uses units where c = 1.
I'm just interested in dropping a clock, so I set dθ and d∅ to zero, reducing the equation to
ds2 = A dt2 - dR2/A
where I have defined A = (1 - α/R) for brevity.
The traveler along this line element will see himself "at rest" and so ds2 will equal dτ2, where τ is the proper time. dτ will equal f dt for some function f of R that reflects slower ticking of the clock as it falls. Thus, we have
f2 dt2 = A dt2 - dR2/A
Rearranging a bit, I get
dR2/A = A dt2 - f2 dt2
Solving for dR/dt yields
dR/dt = (A2 - Af2).5
I then take the derivative to get the acceleration.
d2R/dt2 = .5 (A2 - Af2)-.5 (2A dA/dt - A 2f df/dt - f2 dA/dt))
But, dA/dt = -α/R2 dR/dt, and by hypothesis dR/dt = 0 (we are just dropping an object, whose velocity is initially 0). Therefore, we get
d2R/dt2 = .5 (A2 - Af2)-.5 (- A 2f df/dt))
Since f is a function of R, df/dt = df/dR dR/dt = 0 also initially.
But that means d2R/dt2 = 0 initially as well. So the object does not move!
What's wrong?
You're using trying to use dynamics, but GR is a kinematic theory. This means that the curvature predefines trajectories that will be followed by test particles with given initial conditions and/or proper accelerations. So it is possible to find the 4-velocity of a dropped object but not the way you're attempting.
You should look this up in a textbook, or maybe start with this (very good) article in Wiki.
http://en.wikipedia.org/wiki/Schwarzschild_geodesics
It might be worth noting that:
f2 = A - dR2/(dt2A)
so f is not just a function of R, but a function of R and dt.
These links show how the Schwarzschild acceleration is obtained:
http://www.mathpages.com/rr/s6-07/6-07.htm
http://www.mathpages.com/rr/s6-04/6-04.htm
