How to Remove Blue Boxes in SciDAVis Plotting Application?
  • Thread starter Thread starter syberraith
    Application
In SciDAVis on Debian Linux, users encounter persistent blue boxes around axis labels when exporting plots. Despite efforts to find a setting to remove these boxes, no solution is readily available within the application. A temporary workaround involves closing and reopening the project, which eliminates the blue boxes. Users prefer to resolve the issue directly in SciDAVis rather than using an image editor for post-processing. Overall, the discussion highlights a common frustration with axis label formatting in the plotting application.
syberraith
m using SciDAVis on a Athlon based system running Debian Linux. I am try to produce some graph of functions. The math part is working fine. However, when I try to change the axis labels, a blue box forms around the axis label and remains there.
When I export the plot, the blue box is still there. There seems to be an absence of any setting that I can find to turn off the blue box. I can erase it with a image editor, alhtough I'd rather just get rid of it in SciDAVis if possible.
Mathematics news on Phys.org
OK, well as I start making my way up the new app learning curve, I have noticed that if the project is closed then re-opened the blue boxes go away.
One less thing to worry about...
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 21 ·
