Second Derivative of Circle Not a Constant?
The discussion centers around the second derivative of a circle, specifically questioning whether it can be considered a constant. Participants explore the implications of taking derivatives of the circle's equation and the relationship between curvature and second derivatives, while addressing misconceptions and clarifying definitions.
  • Some participants express confusion about the second derivative of a circle, suggesting a conceptual belief that it should be constant due to the shape of the circle.
  • Others argue that only polynomials of degree 2 or lower can have a constant second derivative, which does not apply to the circle's equation.
  • A participant questions the meaning of "derivative of a circle," emphasizing that derivatives are taken of functions, not geometric shapes.
  • Several participants provide alternative parameterizations of the circle, discussing derivatives in terms of trigonometric functions and their implications for curvature.
  • Some contributions clarify that while the curvature of a circle is constant, this does not equate to the second derivative being constant in the context of the circle's equation.
  • There are discussions about the nature of functions like |x|^2 and their classification as polynomials, with some participants debating the implications of absolute values on polynomial status.
  • Participants highlight that the second derivative's behavior is influenced by the geometry of the circle, particularly at endpoints where tangents become vertical, leading to undefined first derivatives.
  • One participant mentions that every function defined and twice differentiable on an interval whose second derivative is constant is a polynomial, prompting further exploration of this claim.
Participants do not reach a consensus on whether the second derivative of a circle can be considered constant. Multiple competing views remain regarding the interpretation of derivatives in this context and the nature of curvature.
Limitations include the dependence on definitions of functions and the specific context of derivatives taken from the circle's equation. The discussion also highlights unresolved mathematical steps and assumptions regarding the nature of curvature and derivatives.
This discussion may be useful for individuals interested in calculus, geometry, and the properties of curves, particularly those exploring the relationships between derivatives and geometric shapes.
Joseph Nechleba
Using the standard equation of a circle x^2 + y^2 = r^2, I took the first and second derivatives and obtained -x/y and -r^2/y^3 , respectively. I understand that the slope is going to be different at each point along the circle, but what does not make sense to me is that the rate of change of the slope is dependent on the y value of a point along the circle. For some reason, I want to believe that, conceptually, the second derivative of a circle is a constant, which produces the "circle" shape. Can someone please clear my misunderstanding?
Only polynomials of degree 2 or lower can have a constant second derivative.
EDIT: I'm talking about polynomials which only consist of the x variable.
You take the derivative of what with respect to what? What function are you trying to find the derivative of?
What does "derivative of a circle" mean? You can only take derivatives of functions.
A circle is easiest given by x = r⋅cos(t), y = r⋅sin(t), t∈[0, 2π). Then [itex]\dot{x}= -r\cdot \sin(t) = -y[/itex] and [itex]\dot{y}= r\cdot \cos(t) = x[/itex]. Continuing, we get [itex]\ddot{x}=-r\cdot\cos(t)=-x[/itex] and [itex]\ddot{y}=-r\cdot\sin(t)=-y[/itex].
The curvature of a circle is constant.
A vertical parabola has constant second derivative (of its y coordinate as a function of its x coordinate), and only intersects a circle in at most 4 points. Conversely, if we start from the assumption that the second derivative of y is a constant function of x, we may use the Fundamental Theorem of Calculus to imply that the graph of y as a function of x is a parabola. I'm not sure why you believe a circle should have the same second derivative as a parabola.
The expressions you gave are the second derivatives of the y coordinate of a circle over intervals where that coordinate is a function of the x coordinate. The largest interval of x coordinates on which this occurs is [-1, 1], assuming we restrict ourselves to values of y that satisfy either [itex]y\geq 0[/itex] or [itex]y\leq 0[/itex], since otherwise we do not have y as a function of x. These semi-circles are not parabolas, as you can also see by solving for y algebraically and comparing the expression to the standard Cartesian coordinate equation of a parabola.
More geometrically, we note that the second derivative is supposed to tell us the slopes of tangent lines to the graph of the first derivative. The first derivative in turn tells us the slopes of tangent lines to the curve. However, at the endpoints of our semi-circles, the tangent line is vertical, which yields undefined, or infinite, first derivatives. The claim that the second derivative is a constant essentially implies that the graph of the first derivative function is a straight line. This contradicts the geometry of the semi-circle, since straight lines do not approach infinities near -1 or 1 (we are assuming the derivative is continuous, but this is easy enough to show separately).
The curvature of a circle is constant (1 over its radius) and the curvature is related to the second derivative but not equal to it. For y= f(x), the curvature is [tex]\frac{f''(x)}{(1+f'(x)^2)^{3/2}}[/tex]
In differential geometry, the tangent vector at (x, y) is given by [itex]\vec{t}=\frac{\vec{\dot{r(t)}}}{\lvert \vec{\dot{r(t)}} \rvert}=\frac{(-r\sin(t), r \cos(t))}{\sqrt{r^{2}(\sin^{2}(t)+\cos^{2}(t)}}=((-\sin(t), \cos(t))[/itex]. The absolute value of the curvature is given by [itex]\lvert \kappa\rvert=\lvert \vec{t} '\rvert = \lvert \frac{1}{r} (-\cos(t), -\sin(t))\rvert=\frac{1}{r}[/itex].
##|x|^2## is not a polynomial (I think), and it has a constant second derivative.
##|x|^2 = x^2## for all ##x##.
But analytically speaking aren't we first taking the absolute value and then squaring it, so it shouldn't be a polynomial right ? (I wasn't sure of this, that is why I said "I think")
The two functions ##f(x) = x^2## and ##g(x) = |x|^2## are equal. Since ##f## is a polynomial, so is ##g##. The function concept does not address which operation is done first, it only cares whether the inputs and the outputs correspond.
Oh! I see, thanks!
But there are also the floor and ceiling functions which have constant 2nd derivatives, where they are continuous and also the sawtooth function (the fractional part of ##x##) which will have a constant 2nd derivative when ##x## is not an integer.
Every function defined and twice differentiable on an interval whose second derivative is constant is a polynomial.
Hmmmm...I see your point of view.
[Edit:- I am, more or less self taught. So sometimes there exist these small gaps in my knowledge, that make me look like a complete beginner :-)]
Proving that statement...
(D^2)y= k
( D^1) y = kx + C
y(x)= (1/2)k(x^2 ) + C x + K
K,k,c are all constants of integration.
At first glance your proposal seems logical, but does stand up against analysis.
You can disprove your 'intuitive' hypothesis here:
See "Tangent Line" slope here [item 4.3] :
https://en.wikipedia.org/wiki/Circle
Further, maybe think 'intuitively' of the velocity and acceleration [second derivative] perspective:
The tangent line 'slope' is constantly changing direction...so it MUST be a function, not a constant.
Thank you to everyone who replied; everything makes a lot more sense!
When ## x<0 , |x|= -x ; |x|^2= (-x)^2= x^2##. Similar for when ## x \geq 0 ##
For unknown reasons, I can't edit my post post above...#19...
It SHOULD read "...but doesn't stand up against analysis..."
  • · Replies 38 ·
