Second derivative test and hessian matrix
The discussion revolves around the second derivative test for functions of three variables, exploring how it extends from the established two-variable case. Participants examine the implications of the Hessian matrix and its properties in determining local extrema.
  • One participant seeks to understand how to derive the second derivative test for three variables, noting the established two-variable case and expressing confusion about extending the concepts to three dimensions.
  • Another participant explains the representation of the second derivative as a matrix for two variables and discusses the implications of eigenvalues and determinants in determining local extrema.
  • There is a mention of the challenges in interpreting the determinant of the Hessian matrix in three dimensions, where positive determinants do not guarantee all positive eigenvalues, leading to potential saddle points.
  • Several participants inquire about finding critical points for functions of three variables without constraints, indicating a need for clarity on the process.
  • Some participants express frustration over perceived lack of engagement and clarity in the discussion, questioning the relevance of shared links and the specificity of questions posed.
  • One participant references the symmetry of the Hessian matrix and its broader implications, suggesting a desire to explore these concepts further.
Participants do not reach a consensus on the best approach to the second derivative test for three variables, with multiple competing views and some frustration over communication and clarity in the discussion.
Participants express uncertainty regarding the application of the second derivative test in three dimensions, particularly concerning the interpretation of eigenvalues and the determinant of the Hessian matrix. There is also a lack of clarity on the specific questions being asked, which may hinder productive discussion.
clairaut
How does one derive the second derivative test for three variables?
It's clear that
D(a,b) = fxx * fyy - (fxy)^2
AND
fxx(a,b)
Tells us almost all we need to know about local maxima and local minima for a function of 2 variables x and y, but how do I make sense of the second directional derivative of a function of 3 variables x,y,z to form the simple conclusions seen above?
I can easily take the second directional derivative of f(x,y) to derive the above.
The basic idea is this: with a real valued function of two variables, f(x,y), the derivative at a point is, in a strict sense, the linear function that maps the pair (x,y) to a real number that "best approximates" f around that point. That can be represented as a dot product, (f_x, f_y)\cdot (x, y), and so we can represent the derivative as the gradient vector (f_x, f_y).
So the first derivative function maps (x, y) to the vector (f_x , f_y) and its derivative, the second derivative of f, can best be represented as a 2 by 2 <b>matrix</b> <br /> \begin{bmatrix}\frac{\partial^2 f}{\partial x^2} &amp;amp; \frac{\partial^2 f}{\partial x\partial y} \\ \frac{\partial^2 f}{\partial x\partial y} &amp;amp; \frac{\partial^2 f}{\partial y^2}\end{bmatrix}<br /> <br /> Now, two points from Linear Algebra: <br /> 1) Since that is a symmetric matrix, it has two independent eigenvectors and so can be <b>diagonalized</b>. That is, there exist some coordinate system, say x&#039; and y&#039;, such that the second derivative matrix can be written <br /> \begin{bmatrix}\frac{\partial^2f}{\partial x&amp;#039;^2} &amp;amp; 0 \\ 0 &amp;amp; \frac{\partial^2 f}{\partial y&amp;#039;^2}\end{bmatrix}<br /> <br /> 2) The determinant is invariant.<br /> <br /> If f(x,y) at a point, (x_0, y_0) can be approximated by (\partial^2f/\partial x&amp;#039;^2)(x&amp;#039;- x_0)^2+ (\partial^2f/\partial y&amp;#039;^2)(y&amp;#039;- y_0)^2+ f(x_0, y_0) in that x&#039;, y<br /> coordinate system. If the point is a minimum, both those partial derivatives are positive, if it is a maximum, both negative, if a saddle point, one positive and one negative. That is, if either a maximum or minimum, the determinant, \left(\partial^2 f/\partial x&amp;#039;^2\right)\left(\partial^2 f/\partial y&amp;#039;^2\right) is positive, if a saddle point, negative. And because the determinant is &quot;invariant&quot;, that is the f_{xx}f_{yy}- (f_{xy})^2 you refer to.<br /> <br /> Now, here is the problem- and the reason why textbooks do not say what do to in three dimensions. If you go to <b>three</b> variables, x, y, and z, you can still find coordinates, x&#039;, y&#039;, z&#039;, such that the second derivative matrix is diagonal:<br /> \begin{bmatrix} \frac{\partial^2 f}{\partial x&amp;#039;^2} &amp;amp; 0 &amp;amp; 0 \\ 0 &amp;amp; \frac{\partial^2 f}{\partial y&amp;#039;^2} &amp;amp; 0 \\ 0 &amp;amp; 0 &amp;amp; \frac{\partial^2 f}{\partial z&amp;#039;^2}\end{bmatrix}.<br /> <br /> But knowing the <b>determinant</b> of that does NOT tell you anything about the individual signs. If the determinant is positive, it might happen that all three of the signs are positive (a minimum) or that two are negative and the third positive (a saddle point). If the determinant is negative, it might be the case that all three are negative (a maximum) or that two are positive and the third negative (a saddle point). The only thing you really can do is find the individual eigenvalues of the second derivative matrix.
How would you find the critical points of a function with three variables? Let's assume that there are no constraints.
That link brings up 2 variable fxns.
No, it doesn't.
Never mind. I already know about the determinant from hessian matrix. Some so called helpers are very useless.
Does it hurt you to have a discussion?
The information you asked in your previous posts in right there in the link I posted. It has the second derivative test for functions of multiple variables. So what exactly is it that you want to discuss?
Oh I dunno... The wonderful symmetry that Hess found to make his matrix...? The universal application of isomorphism found in his matrix... Stuff like that
You asked about a general test for functions of three variables, I posted it. How am I supposed to know you wanted to talk about the symmetry of the matrix and other stuff? If you have a specific question then please post it. I'm not psychic, so I really don't know what kind of answers you are looking for.
So please, what are the questions you want answers to?
OK, so since you have no specific questions. I am locking this thread.
