Second quantization particle current
The discussion revolves around the expression for charge current in quantum mechanics, specifically questioning the use of an integral sign in the equation provided. Participants clarify that the integral represents a volume integral of a charge density operator, which is unconventional since current density is typically integrated over a surface to yield current. There is confusion regarding the terminology, as the term "current" is usually reserved for surface integrals, not volume integrals. Additionally, the implications of defining currents in this way in curved space are noted, where such definitions may not be well-defined. The conversation highlights a need for further exploration of the concept, particularly in the context of many-body systems and quantum mechanics.
daudaudaudau
Hi. I'm reading an article which writes the following
"... and the well-known expression for the charge current is"
<br /> j=-\frac{ie}{m}\int dr\psi^\dagger (r)[\nabla-ieA(r)]\psi(r)<br />
Why does it have an integral sign? And when you define it this way, you integrate out the r-dependence, don't you?
Strange.
I guess it's not the el.-mag current from QED which does not contain A but carries a four-vector index. Instead it seems to be the probability current for the ordinary Schrödinger equation (with a vector potential) for a particle with mass m. But even in that case there is no integral
I've attached a picture from the particular part of the article (Thermal transport for many-body tight-binding models by Vanderbilt and King-Smith).
OK
The author decided to call the integral a current (referring to the integrand as the current density).
But still he is taking a volume integral of a charge density operator. What is this?
For any extensive physical quantity Q, you can say that it is equal to the volume integral of the DENSITY of Q.
But when would you ever take the volume integral of the current density? The current density is a vector, and it has units A/m^2. What you would normally do is integrate it over a surface to get the current through the surface.
Probably he had something like
<br /> j(r&#039;)=-\frac{ie}{2m}\int dr\psi^\dagger (r) \{\nabla_{r&#039;}-ieA(r&#039;),\delta(r-r&#039;)\}\psi(r)<br />
in mind.
Assume that you have a fluid, each part of which has some momentum density. How would you calculate the momentum of the fluid as a whole?
Yes that sounds sensible, I have just never heard of currents defined in this way before. What should I google to find out more about this?
I think you are right that such global vector quantities are usually not CALLED currents, so googling probably would not help.
In fact, in curved space the integral of a vector field is not even well defined. In other words, in curved space you can associate a vector to a point, but you cannot associate a vector to a whole region of space.
Actually, normally you would obtain a FLUX, which is a scalar, not a vector. See also my post above.
  • · Replies 67 ·
11K
  • · Replies 24 ·
