Comp Sci Seeking Guidance on Working Through Tank Problem with Multiple Tanks
The discussion centers on modeling fluid dynamics between two tanks, focusing on how to derive equations governing the change in fluid height when a valve is opened. Participants express confusion over integrating volumetric flow rates and pressure differences into a coherent mathematical model. Key equations are established, including relationships between flow rates and height changes, but there are concerns about dimensional consistency and the number of equations versus unknowns. The conversation emphasizes the need to simplify the model by eliminating unnecessary variables and ensuring all equations maintain consistent dimensions. The thread concludes with a collaborative effort to refine the equations and clarify the relationships between the variables involved.
Jason-Li
FIGURE 2 shows two cylindrical tanks interconnected with a pipe which has a valve that creates a constant resistance to flow of Rf when fully open. The height of liquid (of density D) in the first tank is Hin and the second tank Hout. The cross-sectional area of the first tank is Ain m2 and the second tank Aout m2.
Q = ( Pin - Pout) / Rf
Hello all I come to again seeking guidance... There is another thread but he seems to have pulled formulas from somewhere other than our learning materials to reach the conclusions.
Looking at this question and I can't figure out where to start really, the examples in out learning materials show the use of just one tank so its more easily done. For example with density being P:
But as qvi = qvo then the right hand side would be effectively 0 as density would also be constant so can't make use of that one..
Was thinking of making an like however unsure of how to work the Q equation into this?
If someone could assist in the way to go with this then I can work through it.
Thanks in advance.
Jason
What is being asked ?
Note: look at the dimension of ##Q## [edit] never mind-- volume flow. I misinterpreted ##h## on first reading...
what thread ? Link ?
Assume density ##D## (is given) is a constant. What is the dimension of your $${A_1\,d\, \rho h_1\over dt}= {A_2\,d \,\rho h_2\over dt}$$ when left and right are divided by ##\rho\ (\equiv D) ## ?
Apologies, the question is as follows:
(a) Produce a mathematical model of the process to determine the change in height of fluid in the second tank when the valve is open.
(b) Determine the time constant for the system.
This is the thread, can't make sense of what is going on.
https://www.physicsforums.com/threads/tank-change-in-flow-process-modeling.966659/
Ok, let's forget the other thread. ( but it did contain the problem specification :wink: )
I edited my post #2
I edited my post #2
Yeah that will cancel out the densities on both side so that
$${A_1\,d\, h_1\over dt}= {A_2\,d \,h_2\over dt}$$
Not sure how to work in the Q figure unless I somehow equate Hin, Ain & Pin
Do you see a [length]3/[time] and doesn't that remind you of the dimension of ##q## ?
Ah so I effectively have Volume / Time, hence volumetric flow rate hence Q = Volume / Time, So I could make the formula:
$$Q={A_1\,d\, h_1\over dt}= {A_2\,d \,h_2\over dt}$$
This look correct?
If so I could make
$${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}-Q$$
$${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}-{P_in-P_out\over R_f}$$
Likes BvU
This look correct?
If so I could make
@BvU think I need to simplify this down further however for the question?
Yes. Next step ?
(Hint: we need another relevant equation that wasn't in the list thus far :wink: )
BvU said:
Yes. Next step ?
So if I look at
then if
$${P}={m\,g\over a}$$
So
$${P}={p\,g\,a\,h\over a}$$
So
$${P}={h*p*g}$$
So would it be productive to make:
$${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}-{({h_1*p*g})-({h_2*p*g})\over R_f}$$
Then as pressure is constant
$${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}-{({h_1*g})-({h_2*g})\over R_f}$$
This look correct? If so I will continue to simplify it down?
I lost the distinction between ##P## and ##p##. Do you mean pressure and density (which is ##D## in the exercise, but usually designated ##\rho##) ?
Coming back to $${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}$$with the dimension of volumeflow. Check it: is it likely ##h_i## and ##h_o## move in the same direction ?
Coming back to $${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}$$with the dimension of volumeflow. Check it: is it likely ##h_i## and ##h_o## move in the dame dierction ?
Sorry yeah I used little p for density.
So putting D back in for p
$${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}-{({h_1*D*g})-({h_2*D*g})\over R_f}$$
Then D can be canceled out still to make :
No in regards to the system as H1 decreases, H2 would increase.
Correct. So $$\begin {align*} Q &= - {A_1\,d\, h_1\over dt} \\ \ \\ Q & = \phantom{-} {A_2\,d \,h_2\over dt} \end{align*}$$ (you want to be a bit more consistent with upper/lower case and subscripts)
and I strongly object against
You can not simply divide by ##D## in one term on side of an equation :mad: ! Check the dimensions !
Instead, you have $$ Q = {\text {see above}}$$
Now, do you see an opportunity to further simplify this ? Does the number of equations match the number of unknowns ?
@BvU
Oh yeah sorry I will work to correct this issue in future. Was a bit lax in my workings there:nb).
I could equate them
$${-A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}$$
I was thinking of doing simultaneous equations but I only have two equations for 4 variables?
I could make
$${-A_2*h_2}={A_1*h_1}$$
Again if i rearrange this and substitute back in it doesn't seem to get me any further?
$${-A_2*h_2}={A_1*h_1}$$ this is the result of an integration, but without the initial conditions !
$$-A_2*(h_2-h_{2,0})=A_1*(h_1-h_{1,0})$$
I count 3 equations for 3 unknowns (##h_1, h_2, Q##) !? What is your 4th unknown ?
@BvU Apologies, I was counting A_1 & A_2 as unknowns but they are still constant.
For your integration I could rearrange it to be
$${-A_2\over A_1} = {h_1-h_{1,0}\over h_2-h_{2,0}}$$
Can't see where to go from here (also you subscripts 0, is the t=0 or 0s)
It's not my integration ! you went from $${-A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}$$ to $${-A_2*h_2}={A_1*h_1}$$ in post #14 and I corrected. However, for the dynamic model this volume balance is not all that interesting. With ##A_1\Delta h_1 = - A_2 \Delta h_2## we can link ##h_1## and ##h_2##. The interesting variable is the driving force
So can you now correct
$${A_2\,d \,h_2\over dt}={A_1\,d\, h_1\over dt}-{({h_1*D*g})-({h_2*D*g})\over R_f} ? $$
and work it around to one equation with one unknown ?
@BvU
Okay so I could change
to
$${A_2\Delta h_2 = A_1 \Delta h_1}-{({h_1*D*g})-({h_2*D*g})\over R_f}$$
But the flow rate will also change with the pressure or height so:
$${A_2\Delta h_2 = A_1 \Delta h_1}-{({\Delta h_1*D*g})-({\Delta h_2*D*g})\over R_f}$$
This does not make sense. First two terms are volumes, third term is a volume flow ! Did you check the dimensions ?
Can you do the exercise without the tank on the right ?
Ah thought I could because the flow rate was given by
$$Q={P_in-P_out\over R_f}$$
So by changing the pressures to the other formula it would still be a flow due to the Rf figure.
Not sure how to do this without the tank on the right as the flowrate is determined by the differential in pressure of the two tanks?
If i go back to:
Which I can equate to
$$\Delta h_2 = {A_1*\Delta h_1*R_f+D*g*(h_2-h_1)\over (A_2*Rf)}$$
And change that to
$$\Delta h_2 = {A_1*\Delta h_1\over A_2}+{D*g*(h_2-h_1)\over (A_2*Rf)}$$
Not sure if I'm going down the correct path here.
$$Q={P_{\text {in}}-P_{\text {out}}\over R_f}= {({h_1*D*g})-({h_2*D*g})\over R_f}$$
This was the third equation I was referring to in post #13. I now regret that at the time I didn't post it explicitly with the other two. Since then we are running around in circles and maze-like sidetracks ! So this time I'll post the complete the set here:
$$\begin {align*}
Q &= - A_1\,{d\, h_1\over dt} \tag{1}\\ \ \\
Q & = \phantom{-} A_2\,{d \,h_2\over dt} \tag{2}\\ \ \\
Q &= \phantom{-} {D\,g\over R_f}\,(h_1-h_2)\tag{3}
\end{align*}$$
no more, except initial conditions ##\;h_{1,0}\;## and ##\;h_{2,0}\;##.
I count eight variables, of which 5 are known. There are three unknowns and three equations. So modelling-wise we are ok. We could give this to an equation solver like Aspen Custom Modeller and be happy with the outcome. However, this is an exercise and the system can be simplified:
Since there is only one driving force ##(h_1-h_2) ## , we now try to work around to one equation in ##{h_1-h_2} ## as unknown with an initial condition ##\;h_{1,0}-h_{2,0}\;##. Namely by eliminating ##Q##.
If you can do that, that would be nice. Otherwise, you can shop around in the other thread, or re-do the single tank exercise
$$\begin {align*}
\end{align*}$$
Thanks for all the help, I feel I may be starting to understand this, thanks for the continued insight!
Okay looking at this if I change Equations 1 and 2 to:
$$Q = -A_1(h_1-h_{1,0})$$
$$Q = A_2(h_2-h_{2,0})$$
Then subtract so
$$0 = A_2(h_2-h_{2,0}) +A_1(h_1-h_{1,0})$$
Then also combine Equations 2 & 3:
$$0 = {D\,g\over R_f}\,(h_1-h_2)-A_2(h_2-h_{2,0})$$
Then equate
$$A_2(h_2-h_{2,0}) +A_1(h_1-h_{1,0}) = {D\,g\over R_f}\,(h_1-h_2)-A_2(h_2-h_{2,0})$$
Which can be made to
$$H_2=(-R_f*A_1(H_1-H_{1,0})-A_2*H_1*R_f+A_2*H_{2,0}*R_f+D*g*H_1) /(D*g)$$
I've eliminated Q but still not sure if I'm pursuing the correct path here?
You can't just change an equation :mad: ! The dimensions left and right become different !
All three equations are in [##Q##] = m3/s
[##Ah##] is m3
[##Ah##] is m3
:oops::oops::oops: Apologies, I'll look at this again.
@BvU
So would it work if I were to
$$0=A_2{dh_2\over dt}+A_1{dh_1\over dt}$$
and
$$0= {D\,g\over R_f}\,(h_1-h_2)-A_2{dh_2\over dt}$$
and
$$A_2{dh_2\over dt}+A_1{dh_1\over dt}={D\,g\over R_f}\,(h_1-h_2)-A_2{dh_2\over dt}$$
and then rearrange for $${dh_2\over dt}$$
Am I pursuing the wrong path here? I am trying to eliminate Q but having a hard time knowing how if I'm honest. Looking to try and make sense of it all and the learning materials are limited to say the least.
The single tank exercise I found quite a bit easier and made
$${dh \over dt} = {Q_i-Q_o \over A}$$
And with ##Q_i=0## and ##Q_o = {p\over R_f}## you get the one-tank version of our exercise that I was aiming at:$$\begin{align*}A{dh\over dt} &= -{Dg\over R_f}\,h \tag{a}\end{align*}$$
The physics: the driving force to reduce ##h## is proportional to ##h## itself. Occurs in radioactivty, height of beer foam, discharging a capacitor, etc.
For the two-tank exercise: what is the driving force and how do you maniplulate ##(1)##, ##(2)## and ##(3)## to get something of the form ##y'= -ky##, like ##(\text{a})##?
Well the driving force is the differential of h1 & h2.
Looking at equations 2 & 3 I could make (with the issue being "k" being positive in the form ##y'= -ky##
$$A_2{dh_2\over dt}={Dg\over R_f}(h_1-h_2)$$
I feel like I need a time aspect on the Right hand side of this formula?
Thanks for sticking with me for this I am learning... slowly
Do you have that in ##y'= -ky## ??
You want something else on the left side ! Something that goes to zero by the time ##h_1=h_2## and you have reached equilibrium.
I don't think so due to the -ky side being positive in my example? also there is a h1 in the k value...
So on the left side, the flow would be zero at equilibrium? Also the difference between the two tanks so I could either include flow or equation 1?
Jason-Li said:
I don't think so
Think again.
You don't want that. Just like in the 1-tank case you want a constant factor there.
What is that ? Or do I have to ask: what are those ? Can you spell it out for me ?When does it (they?) become zero ?
  • #31
To avoid confusion: the expression time aspect does not mean anything to me. Can you explain what you mean ?
Going back to post #21: eight variables, 5 knowns, 3 unknowns and 3 equations. I see I have given away the recipe already but you started to cook up something different.
Let me be more precise:
1. Work around ##(1)## and ##(2)## to get ##Q## as a function of the driving force ##h_1-h_2##. Don't use anything from ##(3)##.
2. Substitute that ##\ Q(h_1-h_2)\ ## in ##(3)##. We now have one first order differential equation (DE) in terms of one time-dependent variable ##h_1-h_2## and the form is like ##\ y'= -ky\ ## with ##k>0##
##Q## has now been eliminated and can be forgotten. If we need it, we can dig up ##(3)## or one of the other two.
3. Invent some initial condition ##\;h_{1,0}, h_{2,0}\;## and and some parameter values (the 5 constants) and solve the DE . Make some plots.
4. See if it all also works if ##\;h_{1,0}< h_{2,0}\;## :smile:
  • #32
BvU said:
Think again.
For the form of y'=-ky k represents a constant, so k would be DG/rf and the y value would be the driving force of h1-h2?
The difference in the hieght gives the driving force e.g. when h1>h2 the pressure in the first tank will cause flow to try and equalise the tanks. h1-h2 will be zero when the tanks are at equilibrium.
I thought before I would need a value of "t" on the right hand side I could hypothetically substitute in.
BvU said:
1. Work around (1) and (2) to get Q as a function of the driving force h1−h2. Don't use anything from (3).
Not going to lie I am unsure of how to do this without touching equation 3, I've done some reading and youtube video watching but can't quite find what I need, e.g. (this uses a state-space model).
I can't equate them as I will lose the Q variable I need to create \ Q(h_1-h_2)\ I could add them together to create
$$2Q = A_2{dh_2\over dt}-A_1{dh_1\over dt}$$
However even if i rearrange this I don't see how I can get to the $$\ Q(h_1-h_2)\$$ ?
Sorry to keep bothering you I feel like we are near a turning point though!
I have spoken to someone else and they advised this:
But we are already at this point in post 21
  • #33
Task at hand:
I'm baffled that you go searching instead of doing some simple math. I can't provide more guidance without robbing you of the exercise, but that can't be helped. See below for what I meant. I am even more baffled that you go so far out in searching, instead of looking in the other thread that you yourself mentioned in post #3 !
Note: I don't mean to be critical or anything, the subject matter is obviously new to you and you need to get acquainted with it. So:What I meant is: ##\ \ ##You have $$
\begin {align*}
\end{align*}$$ and you want something in terms of ##h_1-h_2##.
Perhaps it is a good idea to divide left and right side of ##(1)## by ##A_1## and divide left and right side of ##(2)## by ##A_2##. You then have expressions for ##\ \displaystyle{dh_1\over dt}## and for ##\ \displaystyle {dh_2\over dt}##. What do you get for ## \ \displaystyle{d(h_1-h_2)\over dt \ \ }## ?
So ##\ \displaystyle{Q=\ ...\ {d(h_1-h_2)\over dt }}\ \ ## o_O .
Note: the ... part is constant and will go into the ##k## and that means​
Jason-Li said:
so k would be DG/rf​
Is not completely correct.​
---- also: try to be consistent in your notation: Dg/Rf
So far step 1.
  • #34
@BvU
Apologies I seem to be losing my mind... the only explanation for not seeing thiso_O No offense taken!
So working (1) which you have kindly done.
\begin {align*}
{Q\over A_1}= -{d\, h_1\over dt} \tag{1}\\ \ \\
{Q\over A_2} ={d \,h_2\over dt} \tag{2}\\ \ \\
{Q\over A_1}+{Q\over A_2} =-{d\, h_1\over dt}+{d \,h_2\over dt} \tag{1&2}\\ \ \\
-{Q\over A_1}-{Q\over A_2} ={d\, h_1\over dt}-{d \,h_2\over dt} \tag{1&2 x-1}\\ \ \\
-{Q\over A_1}-{Q\over A_2} ={d\,(h_1-h_2)\over dt} \\ \ \\
Q(-{1\over A_1}-{1\over A_2})=-{d\,(h_1-h_2)\over dt} \\ \ \\
Q= {d\,(h_1-h_2)\over dt} / (-{1\over A_1}-{1\over A_2})\\ \ \\
Q= {d\,(h_1-h_2)\over dt} / ({-A_1-A_2\over A_1A_2})\\ \ \\
Q= -{A_1A_2\over A_1+A_2} * {d\,(h_1-h_2)\over dt} \\ \ \\
\end{align*}
Does this look correct now? with the k factor being:
If so for step 2:
$$-{A_1A_2\over A_1+A_2} * {d\,(h_1-h_2)\over dt} = {D\,g\over R_f}\,(h_1-h_2)$$
So would I work this through until I have:
$${dh_2\over dt}=...$$
  • #35
Jason-Li said:
So would I work this through until I have: ##\ \displaystyle {dh_2\over dt}##
That is not the idea for this exercise, no. You now have $$ {d\,(h_1-h_2)\over dt} =
-{D\,g\over R_f} {A_1+A_2\over A_1 A_2} \,(h_1-h_2)$$Which is of the form ##\ y'= -k\,y\ ##, so easily solved if the initial ##h_{1,0}## and ##h_{2,0}## are given .
When I re-read your post #3 I understand where your interest in ##h_2## comes from. Well, at least now you have the answer for part (b) :wink: .
For part (a): Do you see a path to express ##h_2## when ##h_{1,0}## and ##h_{2,0}## are given and ##h_1-h_2## is known as a function of time ?
  • #36
For Part (b) I can basically follow the other thread as we are at a point now that I can bring the equation to meet the equation here although I don't really see how they did the step shown by the red arrow
For part (a) could I integrate the left hand side between limits of h1-h2 and h1,0-h2,0 to give:
$$(h_1-h_2)-(h_{1,0}-h_{2,0}) = -{D\,g\over R_f} {A_1+A_2\over A_1 A_2} \,(h_1-h_2)t$$
$$-h_2 = -{D\,g\over R_f} {A_1+A_2\over A_1 A_2} \,(h_1-h_2)t+(h_{1,0}-h_{2,0})-h_1$$
Along the right lines here?
  • #37
$$\Bigl .\ln x\,\Bigr |^x_{x_0} = \ln x -\ln x_0$$
I don't think so !
What left hand side ? The ##\displaystyle{dx\over x}\ ## integral was done and gave ## \ln x -\ln x_0## !
How about 'stealing' the answer from the other thread ? Or don't you like it :rolleyes: ?
  • #38
I don't think so !
Thanks for that explanation.
So their final answer of
is suitable for part (a)?
Is their method of identifying the time constant of 63.2% also suitable?
  • #39
Jason-Li said:
So their final answer of ... is suitable for part (a)?
What do you think? Can you find fault?
  • #40
I don't think I can see a mistake with the formula however going back to post #35 where you said to find h2, the attached image in #38 isn't expressly looking for h2 rather dh2/dt but this is likely still correct. Think I have a lot of doubts at the moment, apologies.
In terms of part b if my "time is over tau then the time constant should be 63.2% in line with first order systems
Likes BvU
  • #41
I see what you mean. But I suppose an extra integration is unavoidable. One way to look at it: ##h_2-h_1## (and thereby ##Q##) follows from solving the differential equation & initial conditions. Subsequently ##h_2## follows from ##\ \displaystyle{ \int {dQ\over dt}}##.
It's always good to be critical :smile: . And check things.
Likes Jason-Li
