Self leveling crane pallet fork
  • Thread starter Thread starter Lsos
    Crane Self
The discussion centers on the functionality of self-leveling pallet forks, specifically their ability to maintain a level position regardless of load distribution. Users noted that these forks utilize a spring-loaded hinge mechanism, often enhanced with gas springs for damping, to adjust based on the center of gravity of the load. It was established that self-leveling mechanisms typically require a minimum load of 20% of the Safe Working Load (SWL) to activate, and they are designed to work best with evenly loaded pallets. Uneven loads can lead to instability, particularly when weight is concentrated at the ends of the tines.
  • Understanding of self-leveling mechanisms in crane technology
  • Familiarity with Safe Working Load (SWL) concepts
  • Knowledge of spring-loaded hinge systems
  • Basic principles of load distribution and center of gravity
  • Research the mechanics of gas springs in lifting equipment
  • Explore the design principles of crane forks and their applications
  • Learn about load distribution techniques for pallet handling
  • Investigate alternatives to self-leveling forks, including manual adjustment systems
Engineers, crane operators, and logistics professionals interested in optimizing pallet handling and understanding the mechanics of self-leveling equipment.
Lsos
I’ve been looking at this “Self leveling pallet fork” which is supposed to, as the name suggests, keep itself perfectly level regardless of the load applied.
I guess I can see how it would adjust itself depending on the weight, but I just can’t wrap my head around how it can possibly adjust itself depending on the center of gravity for the weight.
I other words, if the tool picks up a pallet with me on it, I don’t understand how it can possibly keep itself level if I was to walk around on the pallet. If I was standing perfectly still in the center, fine. If I was moving around…I don’t get it. Can anyone help me understand it? Does it maybe work with the assumption that the pallet is perfectly evenly loaded?
[PLAIN]http://www.heidenco.com/images/Pal_Fork.jpg
http://www.youtube.com/watch?feature=player_embedded&v=IEnoJavoFX8
That arm on the top appears to be spring-loaded (and possibly hydraulically-damped as well) so that the connection-point can move to the center of gravity of the load. Nothing is perfect, and you will notice that in the video, the pallets are quite evenly loaded and they are hoisted only after the tines are fully inserted into the pallets. Put a very heavy load out near the ends of the tines, and things might not be as pretty.
Since it's spring loaded, I would expect the connection point to move as a function of weight on the fork. Only.
I just don't see how moving the center of gravity around could possibly cause the spring to stretch and cause the connection point to move.
They are not meant to handle uneven loading over the area of the pallet. The adjustment compensates for the CG position of the weight of the load plus the weight of the fork itself. Like any pallet lift, they are not meant to lift weights using just the tips of the tines either.
As turbo said it is basically a spring loaded hinge, often with a gas spring which also provides some damping.
They usually have a minimum weight of about 20% of the SWL before the auto-levelling kicks in. Below that, the ends of the tines tend to point up, which at least stops light loads from sliding off.
There are simpler and cheaper crane forks with manual adjustment of the lift position, but the automatic ones save time and operator errors handling "mixed" loads.
I see...so basically they work with the assumption that the pallet is evenly loaded. That explains why it didn't make sense to me!
I have encountered a vertically oriented hydraulic cylinder that is designed to actuate and slice heavy cabling into sections with a blade. The cylinder is quite small (around 1.5 inches in diameter) and has an equally small stroke. The cylinder is single acting (i.e. it is pressurized from the bottom, and vented to atmosphere with a spring return, roughly 200lbs of force on the spring). The system operates at roughly 2500 psi. Interestingly, the cylinder has a pin that passes through its...
  • · Replies 22 ·
  • · Replies 28 ·
12K
  • · Replies 18 ·
