Semi-infinite non-conducting rod
  • Thread starter Thread starter kinof
    Rod
3 replies · 4K views · last reply
kinof
A "semi-infinite" nonconducting rod has a uniform linear charge density λ. Show that the electric field E at point P a distance R above one end of the rod makes an angle of 45° with the rod and that this result is independent of the distance R.
$$\vec{E}=\int \frac{k\lambda }{r^2}dx$$
I have found that $$\vec{E_x}=\frac{-k\lambda}{\sqrt{R^2+x^2}}$$ and $$\vec{E_y}=\frac{k\lambda x}{R\sqrt{R^2+x^2}}$$
I have tried to show that, if Ex and Ey make a 45° angle, then they must be equal, but that leads nowhere. I have tried simply taking the arctan of Ey/Ex, but that leads to -x/R, which doesn't make sense. I have also tried evaluating the integrals at infinity and then using L'Hospital's rule, but it doesn't work for Ey.
After integrating, did you evaluate at the limits of integration? ##x## should not appear in the results.
Oh, woops. I got $$\frac{k\lambda}{R}$$ for both. Of course the ratio of these is 1, so the angle is 45 degrees. Thanks.
