Semiconductor doping - doping concentration is 0?
The discussion focuses on calculating semiconductor properties for a germanium sample with a specified acceptor and donor concentration at 400K. The equations for intrinsic carrier concentration, majority carrier concentration, and effective density of states were applied, but there were concerns about the accuracy of the calculations and the use of temperature-adjusted values for Nv and Nc. Participants noted the importance of clearly distinguishing between original and recalculated values, and suggested that long formulas should be simplified for clarity. There was also a mention of discrepancies in the calculated intrinsic carrier concentration (ni) compared to expected values at 300K. Overall, the thread emphasizes the need for careful application of equations and clarity in presenting calculations.
orangeincup
A sample of germaium has an acceptor concentration of Na=10^17 and a donor concentration of Nd=0. Calculate the intrinsic carrier concentration, majority carrier concentration, and Ef-Efi. Use T=400
No*Np=ni^2
Nv=Nv*(T/300)^3/2
Nc=Nc*(T/300)^3/2
ni^2=Nv*Nc exp(Ns)
1.04*10^19 * (400/300)^3/2 = 1.23*10^19 =Nv
6*10^18 * (400/300)^3/2=7.11*10^18 = Ncni=((((1.04*10^19*6*10^18)^2exp(-.66/(2*400*8.6*10^-6)))^1/2
ni=9.21*10^16
10^17/2+sqrt((10^17/2)^2+(9.21*10^16)^2)=1.55*10^17
Does this look correct? I feel like the ni value is wrong
orangeincup said:
Nv=Nv*(T/300)^3/2
Nc=Nc*(T/300)^3/2
Those equations don't make sense.
Likes orangeincup
Isn't the new Nv different at different temperatures? Are you saying it doesn't make sense because I put Nv=Nv, or because I shouldn't use it?
I wasn't sure if I had to re-calculate a new value of Nv and Nc or not, the calculations I did below that used the original values and not the ones I calculated above
What is new, what is old?
Your equations could be "solved" to give T=300. If you want to indicate two different things with Nv, then use different labels.
If you use numbers not given in the problem statement, it would help to explain where they come from (I made this comment before).
Also, for long formulas it is useful to write it in terms of variables first, and then plug in numbers. A large collection of numbers is hard to decrypt, and even harder if the origin of those numbers is unclear.
Likes orangeincup
Nvi=Nvf*(T/300)^3/2
Effective density of states(valence, Nv T=300 K )
Nvf is the new calculated density of states(valence, Nv T=400 K )
The Nc is the same, but for the conduction bandEffective density of states
(conduction, Nc T=300 K )
2.8x10^19
source https://www.el-cat.com/silicon-properties.htm
x^2=((1.04*10^19*6*10^18)*(400/300)^3exp(-.66/(400*8.62*10^-5))
=8.50*10^14, does this look more correct? I fixed errors in my last post
My calculated ni for 300k is off by a bit though... it's suppose to be 2.4*10^13 but I calculated 2.2*10^13 using the same method above. Did I make a mistake?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
