Undergrad What is the difference between sensitivity and efficiency in particle detection?
Sensitivity and efficiency in particle detection are distinct concepts. Efficiency refers to the proportion of particles that a detector successfully identifies out of the total that enter, while sensitivity indicates the detector's ability to identify any particle at all. Sensitivity is often expressed as a ratio of count rate to particle flux, whereas efficiency is a straightforward probability measure. A detector with zero efficiency inherently has zero sensitivity, but the two metrics are not interchangeable. Understanding these differences is crucial for evaluating detector performance in various applications.
kelly0303
Hello! What is the difference between the sensitivity and the efficiency of a detector. In the detector books I found they seem to be treated as 2 different concepts, but based on the descriptions, I can't seem to understand the difference. Efficiency seems to be how many particles you detect out of the total number of particles, while the sensitivity seem to show whether you can detect any particle at all. From this I understand that they are the same thing, but sensitivity outputs basically a 0 or 1 saying of you can detect anything or not, while efficiency outputs a number between 0 and 1 saying how much you actually see. It seems like efficiency implies sensitivity i.e. 0 efficiency detection means 0 sensitivity. What am I missing? Thank you!
Efficiency is the fraction of particles entering the detector that are detected. Sensitivity can be defined as the ratio of the count rate to a unit flux of particles ( particles/sec/cm 2). I am only familiar with one detector in which sensitivity is used and that is a small length BF3 neutron detector used for thermal neutron detection.
I largely see sensitivity used in the context of physics analyses: How common must a physical process be so we expect to see e.g. 1 event, or how large must it be so we see a signal with a significance of 5 sigma, or similar.
Efficiency is much simpler: We have an event (or even a single particle), how likely are we to find it?
  • · Replies 24 ·
