Separation of Variables (PDE) for the Laplace Equation
The discussion focuses on the application of the separation of variables method to solve the Laplace equation using orthogonal functions. The key conclusion is that in the series representation, all coefficients \( a_n \) must be zero except for \( a_1 \), which is derived from the orthogonality of the sine functions over the interval (0, 2). The integral property \( \int_0^2 \sin(\frac{n \pi x}{2}) \sin(\frac{m \pi x}{2}) dx = \delta_{nm} \) confirms that only the term corresponding to \( n = m \) contributes to the sum, leading to the result that \( a_m \sinh(\frac{m \pi}{2}) = 0 \) for \( m \neq 1 \) and \( a_1 \sinh(\frac{\pi}{2}) = 1 \).
  • Understanding of partial differential equations (PDE)
  • Familiarity with the Laplace equation
  • Knowledge of orthogonal functions and their properties
  • Experience with integration techniques in calculus
  • Study the properties of orthogonal functions in more depth
  • Learn about the Fourier series representation of functions
  • Explore the method of separation of variables for other PDEs
  • Investigate the implications of boundary conditions on solutions to the Laplace equation
Mathematicians, physicists, and engineering students who are studying partial differential equations, particularly those interested in solving the Laplace equation using separation of variables and orthogonal functions.
FAS1998
TL;DR
I've attached an image of a solved problem. Can somebody explain the steps in the yellow box? I don't understand how they got to that point from the previous steps.
243695
I suspect it is the first step that is bothering you.
\sum_{n=1}^{\infty}a_n \sin(\frac{n \pi x}{2}) \sinh(\frac{n \pi}{2}) = \sin(\frac{\pi x}{2})
This is true for all values of x. The only way this can be true is for all of the a_n to be zero except a_1. Is this the step that is troubling you? After this, the rest follows pretty easily.
That is the step that is bothering me. Can you explain why all values of a must be 0 except a1?
The functions \sin(\frac{n \pi x}{2}) are orthogonal functions on the interval (0,2). If I integrate:
so it is zero unless n=m. So if you take your original expression, multiply both sides by \sin(\frac{m \pi x}{2}) and integrate both sides you get:
\sum_{n=1}^{\infty}a_n \sinh(\frac{n \pi}{2}) \int_0^2 \sin(\frac{n \pi x}{2}) \sin(\frac{m \pi x}{2}) = \int_0^2 \sin(\frac{\pi x}{2}) \sin(\frac{m \pi x}{2}) dx
This gives a_m \sinh(\frac{m \pi}{2}) = 0 if m is not equal to 1, and a_m \sinh(\frac{m \pi}{2}) = 1 if m = 1.
  • · Replies 36 ·
