Separation of variables to solve DE
9 replies · 2K views
beetle2
y' + (2/x)y = 3/x^2
separation of variables
First I turned it into
dy/dx + (2/x)y = 3/x^2 dx
then multiplied both sides by dx
dy + (2/x)y = 3/x^2 dx
I then tried to divide both sides by 2/x and got
dy + y = 3/2x
Do I just integrate both sides now?
on Phys.org
Separation of variables won't help (you also made an error when multiplying through the equation with dx). It looks like you'll have to solve this using an integrating factor.
You also made an error when dividing by (2/x). Make sure that what you do to one term goes for all terms.
The integrating factor is [itex]e^{\int{\frac{2}{x}dx}[/itex] = [itex]x^2[/itex]
We than use this and multiply both sides by [itex]x^2[/itex]
which gives
[itex]x^2y'+2xy = 3[/itex]
or
[itex]yx^2= 3x+C[/itex]
divide both sides by [itex]x^2[/itex]
[itex]y = \frac{3}{x}+\frac{C}{x^2}[/itex]
Is this the general solution?
yes, it's the general solution.
Also can be solved as a non-homogeneous Euler equation.
boneill3 said:
which gives
or
I see you integrated on the right side wrt x to get 3x+C
but how did [itex]x^2y'+2xy[/itex] become [itex]yx^2[/itex]? did we integrate the LHS wrt x or y?
Given a function [tex]f(x,y)[/tex], its total differential with respect to x is [tex]\frac{df}{dx} = \frac{\partial f}{\partial x}\frac{dx}{dx} + \frac{\partial f}{\partial y}\frac{dy}{dx}.[/tex]
You have to treat both sides of the equation the same way. If you integrate the RHS wrt x, you have to integrate the LHS wrt x as well.
