Sequence based on sequential square root function
9 replies · 2K views
cscott
Express each term of the sequence [tex]\{\sqrt{2}, \sqrt{2\sqrt{2}}, \sqrt{2\sqrt{2\sqrt{2}}}, ...\}[/tex] as a power of 2.
I found [itex]\{2^{\frac{1}{2}}, 2^{\frac{3}{4}}, 2^{\frac{7}{8}}, ...\}[/itex] but I can't get the formula for it so I can find it's limit.
Try a few more then!
Or, it might be better just to write down a way to compute the next term from the current term.
If I consider just the fractional exponents as a sequence on its own, there is no common difference or common ratio so I'm stuck in this aspect.
Do you at least recognize the pattern?
The numerator and denominator go up by 2, 4, 8, 16, etc., or powers of two.
I see... so it'd be like [2^(n) - 1]/2^n ?
It seems to work for the first three!
Be careful with the parentheses. It should read:
2 ^ ((2 ^ (n) - 1) / 2 ^ n), or
[tex]2 ^ {\frac{2 ^ {n} - 1}{2 ^ n}}[/tex]
Well, I thought he was writing down the formula for the exponent, not the term of his sequence!
Yeah, I meant it only as the exponent.
