Series Convergence/Divergence Problem
  • Thread starter Thread starter AxeluteZero
    Series
The discussion revolves around determining the convergence or divergence of a series defined by the summation \(\sum_{n=0}^{\infty} \frac{(-1)^{(n+1)} * 3 - 1}{2^n}\). Participants are exploring the characteristics of this series, particularly in relation to geometric series and their convergence criteria.
  • Participants discuss the nature of the series, comparing it to a previously solved geometric series. There is uncertainty about how the additional term affects convergence and whether the starting index impacts the application of the geometric series formula. Questions arise regarding the significance of the terms involved and the behavior of the series as \(n\) approaches infinity.
The conversation is ongoing, with participants providing insights and suggestions for expanding the series to analyze its behavior. Some guidance has been offered regarding the expansion of terms, but no consensus has been reached on the convergence or the specific sum of the series.
Participants note constraints on the methods available for analysis, specifically that only the geometric series formula can be used, limiting the types of convergence tests applicable to this problem.
AxeluteZero
Does the series converge or diverge? Give reason for your answer; if it converges, find its sum.
[tex]\infty\sum[/tex] n=0 [tex]\frac{(-1)^{(n+1)} * 3 - 1}{2^n}[/tex]
If |r|<1, the geometric series converges to a/(1-r). If |r|> or = 1, it diverges.
[tex]\infty\sum[/tex] n=1 [tex]\frac{(-1)^{(n+1)} * 3}{2^n}[/tex] <---- This is a very similar problem that I was able to figure out.
In this problem, it's a geometric series that converges to 1 (with a sum of [tex]\frac{(3/2)}{1-(-1/2)}[/tex].
However, this particular problem has two differences. One is the -1 on top, which shouldn't matter as n-> infinity since it's so small. The other difference is it starts at zero, so I'm not sure if the above equation (in part "b") is relevant, with a/(1-r). I tried finding an "a" and got -4, but I'm not sure what to do about the r, besides assuming that the 3 and -1 don't matter:
Then I'd get (-1)^n+1 / 2^n which would be 1/2 = r. Help?
Fixed your LaTeX. You can see what I did by double-clicking the summations.
[tex]\sum_{ n=0}^{\infty}\frac{(-1)^{n+1} * 3 - 1}{2^n}[/tex]
[tex]\sum_{n = 1}^{\infty}\frac{(-1)^{n+1} * 3}{2^n}[/tex] <---- This is a very similar problem that I was able to figure out.
Ah, thank you!
I would expand the summation to see how close it is to the summation you've already worked with.
In terms of the series itself, the ACTUAL series I'm working with (with the extra -1) gets closer to zero more slowly than the other.
I can't use the comparison, ratio/root, or integral tests on this either. Only the geometric series formula.
So, in other words...
The top term oscillates between 2 and -4 and the bottom goes to infinity, thus Lim (n -> infinity) = 0 so the series converges to SOME number, correct so far?
If you expand the series you'll see that it is a geometric series. What do the first four or five terms of this series look like?
