Series convergence / divergence
The series \(\sum^{\infty}_{1}(-1)^{n+1}*(1-n^{1/n})\) converges conditionally, as established through the Alternating Series Test. The limit of the term \(a_n = 1 - n^{1/n}\) approaches zero, confirming convergence. However, the positive term \(n^{1/n} - 1\) diverges, which is demonstrated using the Comparison Test against \(\frac{\ln n}{n}\). This analysis confirms that the series does not converge absolutely.
  • Understanding of the Alternating Series Test
  • Familiarity with the Comparison Test
  • Knowledge of limits and convergence criteria
  • Basic calculus concepts, including derivatives
  • Study the Comparison Test in detail for series convergence
  • Learn about the properties of logarithmic functions and their behavior
  • Explore the use of derivatives to analyze increasing and decreasing functions
  • Investigate absolute vs. conditional convergence in series
Mathematics students, educators, and anyone studying series convergence and divergence, particularly in calculus and analysis courses.
goraemon
Does the following series converge or diverge? If it converges, does it converge absolutely or conditionally?
Alternating series test
I started out by taking the limit of ##a_n: Lim_{n\rightarrow\infty}(1-n^{1/n})##=1-1=0.
So via the alternating series test, the original series converges.
Next, I have to figure out whether it converges absolutely or conditionally, and this is where I'm stuck. I suppose I have to first find out whether the term ##a_n##, which is ##(1-n^{1/n})##, diverges or converges. But what test do I use for this? The limit test is silent because as I found above, the limit is zero. I've tried ratio test and limit comparison test to no avail. Root test doesn't seem to lead anywhere. It's not a geometric or telescoping series so those options are out. Maybe I could use comparison test, but I don't know what term I would use for comparison. Integral test seems really difficult. So I'm stuck and would appreciate any helpful pointers.
think about [(n^(1/n)-1)/(1/n)]/n
compare to log(n)/n
Wait, so...I gather you're saying that ##\sum(-1)^{n+1}*(1-n^{1/n})=\sum(-1)^n*(n^{1/n}-1)##, so when we consider the positive term ##(n^{1/n}-1)##, it can be re-written as:
##\frac{(n^{1/n}-1)*n}{n}##, aka:
##\frac{\frac{(n^{1/n}-1)}{\frac{1}{n}}}{n}##?
And from here we do a comparison test with ##\frac{\ln n}{n}##? OK, From punching some numbers into the calculator, I can see that ##\frac{\frac{(n^{1/n}-1)}{\frac{1}{n}}}{n} > \frac{\ln n}{n}##, so via the comparison test the positive term diverges, meaning the original alternating series converges conditionally?
But if so, then I'm not sure how to show rigorously that ##\frac{\frac{(n^{1/n}-1)}{\frac{1}{n}}}{n} > \frac{\ln n}{n}##, other than to say it seems to be true for some arbitrarily large n...am I on the right track here?
^Exactly
n^(1/n)-1>=0 for all n (n=1,2,3,4,...)
x>=log(1+x) for all x (x>=0)
thus
n^(1/n)-1>log{1+[n^(1/n)-1]}=log(n)/n
∑log(n)/n diverges so too does ∑[n^(1/n)-1]
You can use derivatives to show this (increasing/decreasing functions).
