Series Convergence: Is the Root Test Always Reliable?
  • Thread starter Thread starter freshman2013
    Root Test
6 replies · 4K views
freshman2013
determine whether the series (1-1/n^(1/3))^n converge or diverge
all the testing procedure
So I did the root test first, but the limit on the inside is 1. I then tried the ratio test but then when I tried taking the limit, I ended up with e^(-infinity+infinity). Finally, I tried the test for divergence on the original series, but i turned out be zero so it might or might not converge. Now I'm totally stuck.
You should never end up with something like this ( -∞ + ∞), as it is indeterminate. I agree with what you got on the root test, so that's not a useful test, and the n-th term test seems to give a value of 0, so it doesn't tell us anything.
I would take another look at the ratio test to see what the limit actually is.
If
[tex]t_n = \left(1 - \frac{1}{n^{1/3}}\right)^n,[/tex]
you can look at ##L_n = \ln(t_n)## and use the series expansion of ##\ln (1-x)## for small ##x = 1/n^{1/3}##, to get the behavior of ##t_n## for large n. In fact, you can even get a simple upper bound ##u_n##, so that ## 0 < t_n < u_n##, and ##\sum u_n## is easy to analyze.
Mark44 said:
The OP might not have been exposed to series yet...
Series are not really needed here; it is enough to know that 1-x < exp(-x) for x > 0, so that ln(1-x) < -x for small x > 0.
Anyway, if the OP has seen series the method could be useful; if he/she has not yet seen series it is perhaps not useful. However, I have no way of knowing what the OP has, or has not, seen.
