Proving Set Equality: A Simple and Effective Method
The discussion focuses on proving set equality by demonstrating that each side is a subset of the other. Participants emphasize the importance of avoiding assumptions about finite intersections, especially when dealing with potentially infinite or uncountable sets. The use of quantifiers like "for all" (∀) is recommended to generalize the proof and eliminate reliance on finite indices. Additionally, the need for clarity in proofs involving unions of indexed sets is highlighted, suggesting the use of "there exists" (∃) for such cases. The thread concludes with a request for account reinstatement from a user, which leads to the closure of the discussion for moderation.
Jairo Rojas
Attached is the problem
So I have to show that each side is a subset of the other side
Assume x∈ A ∪ (∩Bi)
so x∈A or x∈∩Bi
case 1 x∈ ∩ Bi
so x∈ (B1∩B2∩B3...∩Bn)
which implies x∈B1 and x∈B2 ... and x∈Bn
so x∈B1∪A and x∈B2∪A... and x∈Bn∪A
so x∈∩(A∪Bi)
My teacher told me that this approach doesn't work because the sets can be infinite and told me to use "words". I don't what he meant with that.
You don't need to use words instead of symbols, though you could. What you do need to do is avoid writing it as a finite (or even countably infinite) intersection. It is not hard to convert your proof to one that works.
can I say n->infinity?
what about if I split (∩Bi) into two finite sets call it S and B so it equals SnB
The problem is that by writing x∈ (B1∩B2∩B3...∩Bn) you have assumed that the index set ##I## has only ##n## elements. But in fact it may be infinite, or worse, uncountable. That assumption cannot be made because it may be false. Consider for instance if the index set ##I## is the set of all real numbers in the interval [0,1) and ##B_j## for ##j\in I## is the set of all positive real numbers whose fractional part is ##j##. Then ##I## is uncountably infinite.
To avoid making that invalid assumption, use the quantifier ##\forall##, which means 'for all'.
So you have ##x\in\bigcap_{j\in I} B_j## and instead of writing
you write ##\forall j\in I:\ x\in B_j##.
Similarly for the rest of your proof: wherever you find yourself using ##n## or an ellipsis (that's the '...' you've written in the middle of lists), get rid of them by re-writing using ##\forall##.
When you come to do similar proofs for unions of indexed sets you will need to use the other quantifier ##\exists##, which means 'there exists' ('there is at least one').
thanks!
by the way I am theMathNoob. can you ask the administrator to unban my account?. I promise I won't post silly ps4 questions.
Thread closed for Moderation...
12K
