Solve Sets of Form $v+X$ in $\mathbb{R}^2$
  • Context: MHB
  • Thread starter Thread starter mathmari
    Form Sets
This discussion focuses on solving sets of the form \( v + X \) in \( \mathbb{R}^2 \), where \( v \) is a vector and \( X \) is a subset of \( \mathbb{R}^2 \). The participants analyze specific lines \( L, L_1, L_2, \) and \( L_3 \) defined by \( L = \mathbb{R}\begin{pmatrix}1 \\ 2\end{pmatrix} \) and shifted versions of \( L \). They confirm that \( w \in v + L \) leads to \( w + L = v + L \) and discuss the implications of intersections of these sets. Additionally, they establish the equality \( v + (w + X) = (v + w) + X \) through logical equivalences.
  • Understanding of vector operations in \( \mathbb{R}^2 \)
  • Familiarity with linear equations and lines in a coordinate system
  • Knowledge of set operations and properties of intersections
  • Ability to manipulate and interpret mathematical expressions and equivalences
  • Explore the properties of vector addition in \( \mathbb{R}^2 \)
  • Study the geometric interpretation of linear transformations
  • Learn about the implications of set intersections in vector spaces
  • Investigate the concept of affine combinations and their applications
Mathematicians, students studying linear algebra, and anyone interested in understanding vector spaces and their geometric interpretations.
mathmari
MHB
Hey! 😊
Let $v\in \mathbb{R}^2$ be a vector and let $X\subseteq \mathbb{R}^2$ be a subset, then we define the subset of $\mathbb{R}^2$ : $$v+X:=\{v+x\mid x\in X\}$$
Let \begin{equation*}L:=\mathbb{R}\begin{pmatrix}1 \\ 2\end{pmatrix}=\left \{\begin{pmatrix}x \\ y \end{pmatrix}\mid 2x-y=0\right \}\end{equation*} and let \begin{equation*}L_1:=\begin{pmatrix}3 \\ 0\end{pmatrix}+L , \ , L_2:=\begin{pmatrix}-1 \\ -1\end{pmatrix}+L , \ , L_3:=\begin{pmatrix}0 \\ 1\end{pmatrix}+L\end{equation*}
(a) Draw the sets $L, L_1, L_2, L_3$ in a coordinate system and show the following for each $v, w\in \mathbb{R}^2$ :
(i) $w\in v+L\Rightarrow w+L=v+L$
(ii) $(v+L)\cap (w+L)\neq \emptyset \Rightarrow w+L=v+L$
(b) Show for all $v, w\in \mathbb{R}^2$ and $X\subseteq \mathbb{R}^2$ that $v+(w+X)=(v+w)+X$.
I have done the following:
(a) To draw the sets : $L$is the points on the line $y=2x$, right? All the other sets are lines that have been shifted?
(i) Let $w\in v+L$.
This means that $w=v+\ell$, with $\ell\in L$.
We have that \begin{align*}x\in w+L& \iff x=w+\ell_1 , \ \ell_1\in L \\ & \iff x=(v+\ell)+\ell_1=v+(\ell+\ell_1) , \ \ell+\ell_1\in L \\ & \iff x\in v+L\end{align*}
So we get the equality $w+L=v+L$.
Is it corrct to use everywhere $\iff$ ?
(ii) Let $(v+L)\cap (w+L)\neq \emptyset$.
Then there is an element in the intersection, say $x$.
So $x\in (v+L)\cap (w+L)$ means that $x\in (v+L)$ and $x\in (w+L)$. Do we use now the stetement of (i) to get the desired result? (b) Do we have here the following equivalences \begin{align*}y\in v+(w+X) &\iff y=v+(w+x) , \text{ with } x\in X \\ & \iff y=(v+w)+x \\ & \iff y\in (v+w)+X\end{align*} :unsure:
Hi mathmari!
Yes.
Btw, your definition \begin{equation*}L:=\mathbb{R}\begin{pmatrix}1 \\ 2\end{pmatrix}=\left \{\begin{pmatrix}x \\ y \end{pmatrix}\mid 2x-y=0\right \}\end{equation*} is the same as \begin{equation*}L:=\mathbb{R}\begin{pmatrix}1 \\ 2\end{pmatrix}=\left \{\lambda\begin{pmatrix}1 \\ 2 \end{pmatrix}\mid \lambda\in\mathbb R\right \}\end{equation*}
I think the latter is a bit easier to understand. 🤔
(i)
Is it correct to use everywhere $\iff$ ?
If I try to follow the argument in the reverse direction, it doesn't make much sense.
That is, we'd get as the first reverse step
\begin{align*}x\in v+L\implies x=(v+\ell)+\ell_1=v+(\ell+\ell_1) , \ \ell+\ell_1\in L \end{align*}
It's not exactly wrong because we can verify each reverse step with some extra thought, but I think it's better to make the argument for the reverse direction separately.
That is easier for the reader to understand, not to mention that it is easy to make mistakes otherwise. 🤔
Yep. That works. (Nod)
The last reverse step looks suspicious
$$y\in (v+w)+X\implies y=(v+w)+x$$
This is not generally true. If y in a set that does not imply that it is equal to some specific element in that set. 🧐
The converse is true though: if y is a specific element in a set, then y is an element of that set.
What is missing, is that we only require that "there is an $x\in X$" for which it applies, which you left out.
Either way, again I think it is better to make the reverse argument separately to avoid mistakes, and to make it easier for the reader to understand and verify. 🤔
Now I am confused. I understand your definition, but why is this the same with $\left \{\begin{pmatrix}x \\ y \end{pmatrix}\mid 2x-y=0\right \}$ ? How do we get the "minus" from your definition? :unsure:
So,to show that $w+L \subseteq v+L$ we have :
\begin{align*}x\in w+L& \Rightarrow x=w+\ell_1 , \ \ell_1\in L \\ & \Rightarrow x=(v+\ell)+\ell_1=v+(\ell+\ell_1) , \ \ell+\ell_1\in L \\ & \Rightarrow x\in v+L\end{align*}
And to show that $v+L \subseteq w+L$ we have :
\begin{align*}x\in v+L& \Rightarrow x=v+\tilde{\ell} , \ \tilde{\ell}\in L \\ & \Rightarrow x=v+\ell-\ell+\tilde{\ell} , \ \tilde{\ell}\in L \\ & \Rightarrow x=w+(\tilde{\ell}-\ell) , \ \tilde{\ell}\in L \\ & \Rightarrow x\in w+ L\end{align*}
:unsure:
I got stuck right now. Because at the previous statement we had $w$ and then the set $w+L$. Here we take an arbitrary $x$, or not? :unsure:
It holds that
\begin{align*}y\in v+(w+X) &\Rightarrow y=v+(w+x) , \text{ with } x\in X \\ & \Rightarrow y=(v+w)+x \\ & \Rightarrow y\in (v+w)+X\end{align*}
It also holds that
\begin{align*}y\in (v+w)+X &\Rightarrow y=(v+w)+x , \text{ with } x\in X \\ & \Rightarrow y=v+(w+x) \\ & \Rightarrow y\in v+(w+X)\end{align*}
Sowe get the equality $v+(w+X)=(v+w)+X$, right? :unsure:
We get $x=\lambda$ and $y=2\lambda$ from "my" definition.
Substitute in $2x-y=0$ to find $2\cdot\lambda - 2\lambda=0$.
So they are the same aren't they? 🤔
Your version is actually a reworked version of the general definition, which is the one I gave.
Yours is a bit of an awkward definition though. (Bandit)
Didn't we have $w$ and then the set $v+L$ instead in the previous statement?
Now we have $x\in w+L\implies x+L=w+L$ when we apply the previous statement. And we also have $x\in v+L\implies x+L=v+L$. 🤔The rest is all correct. (Nod)
Thanks for the explanation, I understodd that now! :giggle:As for the graphs.
We have that $$\begin{pmatrix}x\\ y\end{pmatrix}\in L_1 \ \text{ then } \ \begin{pmatrix}x\\ y\end{pmatrix}=\begin{pmatrix}3\\ 0\end{pmatrix}+\begin{pmatrix}\lambda \\ 2\lambda \end{pmatrix}=\begin{pmatrix}\lambda+3 \\ 2\lambda \end{pmatrix}$$
So we set $x=\lambda+3$ and $y=2\lambda \Rightarrow \lambda=\frac{y}{2}$ then substituting this in the first equation we get $x=\frac{y}{2}+3 \Rightarrow y=2x-6$. \begin{equation*}\begin{pmatrix}x\\ y\end{pmatrix}\in L_2 \ \text{ then } \ \begin{pmatrix}x\\ y\end{pmatrix}=\begin{pmatrix}-1\\ -1\end{pmatrix}+\begin{pmatrix}\lambda \\ 2\lambda \end{pmatrix}=\begin{pmatrix}\lambda-1 \\ 2\lambda-1 \end{pmatrix}\end{equation*}
So $x=\lambda-1$ and $y=2\lambda -1\Rightarrow \lambda=\frac{y+1}{2}$ so we get $x=\frac{y+1}{2}-1 \Rightarrow y=2x+1$.
\begin{equation*}\begin{pmatrix}x\\ y\end{pmatrix}\in L_3 \ \text{ then } \ \begin{pmatrix}x\\ y\end{pmatrix}=\begin{pmatrix}0\\ 1\end{pmatrix}+\begin{pmatrix}\lambda \\ 2\lambda \end{pmatrix}=\begin{pmatrix}\lambda \\ 2\lambda+1 \end{pmatrix}\end{equation*}
So $x=\lambda$ and $y=2\lambda +1\Rightarrow y=2x +1$. (So we get the same line as the previous one?) :unsure:
mathmari said:
As for the graphs.
We can do it a little bit easier.
From "my" definition it should be clear that $L$ is a line through the origin with directional vector $\begin{pmatrix}1\\2\end{pmatrix}$.
The others are the same line but through the points $\begin{pmatrix}3 \\ 0\end{pmatrix}$, $\begin{pmatrix}-1 \\ -1\end{pmatrix}$, respectively $\begin{pmatrix}0 \\ 1\end{pmatrix}$ instead of through the origin. :geek:
If we add the directional vector to the second one, we get the third one. So these are indeed the same lines. (Nod)
  • · Replies 52 ·
