Undergrad Is it possible for non-spherical atomic orbitals to have spherical symmetry?
Non-spherical atomic orbitals, such as p and d orbitals, lack spherical symmetry, while the atomic Hamiltonian exhibits spherical symmetry. This discrepancy arises because the symmetry of the Hamiltonian applies to the entire set of solutions rather than individual orbitals. Even though individual orbitals may appear unsymmetrical, collectively they maintain spherical symmetry, similar to how a spherically symmetric gravitational field can influence non-symmetric planetary orbits. The shape of orbitals affects electron dynamics, leading to varying probabilities of electron presence in different directions. Ultimately, the symmetry of the Hamiltonian ensures that eigenstates remain consistent under rotation, despite the lack of symmetry in individual orbitals.
hokhani
TL;DR
The non spherical orbitals of spherical Hamiltonian
Oritals, other than s-orbitals, don't have spherical symmetry while the atomic Hamiltonian does have spherical symmetry. How is this possible?
hokhani said:
Summary:: The non spherical orbitals of spherical Hamiltonian
You can compare this to the case of a free particle in 1D. The Hamiltonian operator
##\displaystyle\hat{H} = -\frac{\hbar^2}{2m}\frac{d^2}{dx^2}##
is invariant in any coordinate translation ##x\mapsto x+\Delta x##, but the energy eigenstates are of form
##\displaystyle\psi (x) = Ae^{ikx} + Be^{-ikx}##
which are not translation invariant unless ##k=0## and ##\psi## is a constant function.
Likes aaroman
Because the symmetry of the Hamiltonian shows up in the symmetry of the entire set of solutions, not in every individual solution. The entire set of solutions has spherical symmetry, but not all individual solutions do.
Likes aaroman
hokhani said:
Orbitals, other than s-orbitals, don't have spherical symmetry while the atomic Hamiltonian does have spherical symmetry. How is this possible?
That's true of any central force problem, even classically. For example the Sun's gravitational field is (too good approximation) spherically symmetrical but the solar system obviously is not.
Likes Vanadium 50
The reason is that the named orbitals commonly drawn are basis-dependent. It is like drawings of a circle from different (basis-dependent) perspectives, which produces unsymmetric ellipses.
The general orbital is quite arbitrary, and the set of all orbitals has spherical symmetry.
Likes aaroman, vanhees71 and TeethWhitener
Exercise: Show that the sum of the norm of all orbitals of a given angular momentum ##l##, i.e.,
\sum_{m=-l}^l \left| Y_{l,m} (\theta, \phi) \right|^2
is spherically symmetric.
Suppose that an electron is in a d-orbital, say ##d_{z^2}## . The probability of existence of electron in one direction may be different from that in another direction! I think this discrepancy can be explained as follows:
There is no preferred z-direction and the shape of orbitals helps to determine the dynamics of electrons.
What is the source of atoms?
If the source is a thermal one, then there will be an equal probability of the atom being in all states of the same energy, as is the case for states that only differ in the magnetic quantum number. In that case, the electronic distribution is isotropic, see my post #6 above.
If the atom is in a specific state, as in your example above, then there was some state preparation (or selection) and there is no requirement for an isotropic distribution, since the preparation process can break the symmetry. In that case, the atom is said to be polarized, and there is a preferred direction for the electron.
Likes hokhani, vanhees71, PeroK and 1 other person
Eigenfunctions of spherically symmetric Hamiltonians actually do have spherical symmetry, just not in the sense that you're thinking of. Say you have a Hamiltonian ##H## with spherical symmetry, i.e. ##[H,U(\theta)]=0## , then eigenstates ##|\omega\rangle## of ##H## will remain eigenstates with the same eigenvalue under rotation.
Likes aaroman, hokhani and vanhees71
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 47 ·
