How Is Shearing Modulus Used to Calculate Force in Punching a Hole in Steel?
To calculate the force required to punch a hole in steel, the shearing modulus is used, which relates shearing stress to shearing strain. The equation involves determining the shearing stress by dividing the force by the area of the hole. The area is calculated using the formula A = π/4 (1/2)^2 for a ½ inch diameter hole. The challenge arises from not having the length sheared (S), which is necessary for completing the calculation. Understanding the relationship between shearing strength and the equation is crucial for determining the force needed, even without the specific value of S.
Myung
How much force is required to punch a hole ½ in. in diameter from a 1/8 in. thick steel sheet of shearing strength 4x10^4 psi.
Shearing Modulus = Shearing Stress / Shearing Strain
Shearing Stress = F/A
Shearing Strain = S/L
S = Length Sheared
L = Length to be sheared
FIND: FORCE IN lb-f
thus:
shearing modulus ( shearing strain ) = Shearing Stress
4x10^4 PSI * ( S/L ) = F/A
A = ∏/4 (1/2)^2
(∏/4 (1/2inch)^2)*(4x10^4 PSI)*(S)
------------------------------------- = Force
1/2 inch
I don't know what S to use because the length sheared(S) is not given.
Can i still solve the equation without the length sheared(S)?
JaWiB said:
Can you atleast explain to me the relationship of Shearing Strength to this equation and how I can use the value of the Strength of the object to get the force?
10K
