Shifting integration variable when determing population densities
8 replies · 2K views · last reply
"Don't panic!"
Hi,
I'm hoping someone can enlighten me on this as I'm a little bit fuzzy on the reasoning:
Say I have a space-time dependent field [itex]B_{a}[/itex] that interacts with fermions such that it affects their energy dispersion. It appears in the energies in the form
[tex]E\sim\sqrt{\left(\vec{p}+\vec{B}\right)-m^{2}}+B_{0}[/tex]
Why is it, that when I then calculate the number density of fermions in such a scenario, i.e.
[tex]n\sim\int^{+\infty}_{-\infty}\frac{d^{3}p}{\left(2\pi\right)^{3}}\frac{1}{\exp{\left(E/k_{_{B}}T\right)}+1}[/tex]
(where in this case the chemical potential is negligible) that I can only shift the integration variable, such that [itex]\vec{p}\rightarrow \vec{p}+\vec{B}[/itex] (thus "absorbing" the 3-vector components of [itex]B_{a}[/itex]), if I consider [itex]B_{a}[/itex] to be constant?
Thanks in advance!
Apologies for the spelling mistake in the title of the thread by the way, should be "determining" , but don't know how to retroactively edit it!
What do you think would happen to d3p if B is not constant?
Would it be that it becomes time dependent and thus coupled to the fluctuations in B over time?
or more explicitly, that you would also introduce an additional integral over [itex]d^{3}B[/itex]?
Slow down with the questions and answer my question in post #3
sorry, they were my attempts at a possible answer (shouldn't have included the question marks)!
I assume that you would have [itex]d^{3}p\rightarrow d^{3}\left(p+B\right)=d^{3}p'[/itex] and so, as B is not constant, one could not talk of set momentum states for the fermions as they would fluctuate in time depending on the fluctuations in B.
Correct. If you have a explicit form for B then you might attempt a solution. You can't go much further with the general expression, I don't think
ok, that's cleared things up a bit. Thanks for your time.
