Shortest distance between A(2,1,-2) and the line x=3-2t;y=-4+3t;z=1+2t.
The shortest distance between point A(2,1,-2) and the line defined by the parametric equations x=3-2t, y=-4+3t, z=1+2t can be calculated using multiple methods. One effective approach involves finding the plane perpendicular to the line that passes through point A, represented by the equation -2(x-2) + 3(y-1) + 2(z+2) = 0. Another method utilizes vector operations, specifically the cross product of a vector from a point on the line to point A and a unit direction vector of the line, yielding the distance as d = |\vec V × \hat D|. Both methods provide a definitive solution without reliance on trigonometric functions.
  • Understanding of parametric equations of a line
  • Knowledge of vector operations, including cross products
  • Familiarity with calculus concepts, particularly differentiation
  • Ability to derive equations of planes in three-dimensional space
  • Study the derivation of the equation for a plane given a point and a normal vector
  • Learn about vector cross products and their geometric interpretations
  • Explore methods for minimizing functions using calculus
  • Investigate applications of parametric equations in three-dimensional geometry
Students studying calculus and geometry, particularly those focusing on vector analysis and optimization problems in three-dimensional space.
gikiian
Find the shortest distance between A(2,1,-2) and the line having parametic equations:
x=3-2t;
y=-4+3t;
z=1+2t.
After derivation:
d = |AB| sin( arccos( (AB.BC)/|AB||BC| ) )
B and C are points on the line found by putting random values for t.
For t=0 -> B(3,-4,1)
For t=1 -> C(1,-1,3)
Plugging the values in the above equation, we get:
d = 6 sin (arccos 11/6sqrt(17) )Using the calculator gives the correct answer, but there is another way which I can't figure out, in which you get the answer irrespective of sin and arccos.
What is it?
Thanks in advance :)
You could write down the distance squared between A and (x,y,z), then differentiate with respect to t and look for a minimum if you know calculus.
Another way to do this, and I think simpler, is to find the plane perpendicular to the given line, passing through the given point. The point on the line closest the given point- from which the shortest distance from the given point to the line is measured- is where the line intersects that plane.
The plane perpendicular to the line x=3-2t; y=-4+3t; z=1+2t, through the point (2, 1, -2) is given by -2(x- 2)+ 3(y- 1)+ 2(z+ 2)= 0. Putting the equations for the line into that we get -2(3- 2t- 2)+ 3(-4+ 3t- 1)+ 2(1+ 2t- 2)= 4t+ 9t+ 4t+ 4- 12+ 4= 25t- 4= 0. find the point corresponding to that t and the distance between that poiunt and (2, 1, -2).
Another purely vector method is to make a unit vector out of the direction vector:
\hat D = \frac 1 {\sqrt{17}}\langle-2,3,2\rangle
and a vector across from any point on the line to the point off the line, for example from (3,-4,1) to (2,1,-2):
\vec V = \langle -1,5,-3\rangle
Then the distance is the magnitude of the cross product:
d = |\vec V \times \hat D|
All the sine and cosine stuff is hidden in the vector operations.
9K
