Shortest distance between two lines
The problem involves finding the shortest distance between two lines defined in three-dimensional space, specifically given by the equations A = (1,2,3) + t(0,1,1) and B = (1,1,1) + s(2,3,1).
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to determine the shortest distance by finding a vector AB that is orthogonal to both lines, leading to a system of equations. Some participants confirm this method and suggest alternative approaches, including using cross products and projections.
Participants are exploring various methods to solve the problem, with some confirming the original poster's approach while others suggest different techniques. There is no explicit consensus on a single method, but multiple viable approaches are being discussed.
The original poster expresses uncertainty about their solution and seeks validation, indicating a desire for clarity on the correctness of their reasoning and potential alternative methods.
Anden
I'm a bit uncertain about this question and would like some help, as I don't have the correct answer. Have I done this correctly?
What is the shortest distance between the two lines A = (1,2,3) + t(0,1,1) and B = (1,1,1) + s(2,3,1)
My reasoning: The vector AB is shortest when AB is orthogonal to BOTH A and B.
Therefore the scalar product AB [tex]\circ[/tex] A = AB [tex]\circ[/tex] B = 0. That gives a system with two equations
AB = (2s, -1+3s-t, -2+s-t)
AB [tex]\circ[/tex] A = -3+4s-2t=0
AB [tex]\circ[/tex] B = 14s-5-4t=0
which when solved gives s = -1/6 and t = -11/6.
I now seek |AB|, or the LENGTH of the vector.
Substituting s and t with the corresponding values and then using Pythagoras gives:
|AB| = sqrt(1/3)
Is this correct? Is there perhaps an easier way to do this?
Danke schön!
Yes, your method is correct. Another approach that doesn't involve simultaneous equations is to cross the two direction vectors and make a unit normal n from it. That gives the orthogonal direction. Then let V be a vector from a point on one line to a point on the other.
Then d = |V dot n|
Then d = |V dot n|
Worked excellent, thank you. I also noticed that I could use the normal vector without turning it into a unit vector. I used it to create a system of equations
1+2s=1-2a
1+3s=2+t+2a
1+s=3+t-2a
which gives that a = 1/6
Then I multiplied that(1/6) with (-2,2,-2) and then used Pythagoras to calculate the length of the vector, which in this case is 1/sqrt(3).
or you could use projection
