Should I Normalize My Discretized Integral?
  • Level: Graduate
  • Thread starter pamparana
    Integral
2 replies · 4K views · last reply
pamparana
Hello everyone,
I have an integral as follows:
[itex]\log(\int_{r}^{\inf}\frac{P(v,f)}{P(f)}dv)[/itex]
Now, I want to evaluate this on the computer where this PDF represented by P(v, f) is build up using a joint histogram where each entry is a probability for a given value pair for v and f to occur together.
Now when I compute this integral I do it as follows:
[itex]\sum_{r}^{bins}\frac{P(v,f)}{P(f)}[/itex]
where v and f are some appropriate values and bins are the number of bins along the appropriate axes in my joint histogram. Then after accumulation, I take the log of the final value.
Now, my question is that do I need to normalize this somehow? When discretizing such integrals does one normalize it by the range of the definite integral parameters?
Thanks,
Luca
You should make a graphic. What you basically do is to approximate the integral by a Riemann sum. This involves the split of the distance into equidistant sections.
You're missing a term.
As @fresh_42 says, you appear to be doing a Riemann sum, approximating ##\int_a^b f(x) dx## by ##\sum_{i=1}^n f(x_i) \Delta x ## = ##\Delta x \sum_{i=1}^n f(x_i)## if all the bins are the same size. So you need the ##\Delta x##.
