Anonymous217
- 355
- 2
If we're considering a change in denoting pi, consider a change in denoting the set of primes, ie. \displaystyle \prod_{p \text{ prime}}.
The discussion centers on the proposal to replace the mathematical constant pi with tau, defined as tau = 2*pi. Proponents argue that tau simplifies trigonometric calculations and aligns better with the radius-based definitions of circles, while opponents assert that pi is a well-established constant that should not be changed. Key points include the confusion that may arise from changing conventions and the practicality of measuring diameters versus radii. Ultimately, the debate highlights the tension between mathematical tradition and potential simplification.
PREREQUISITESMathematicians, educators, students of mathematics, and anyone interested in the evolution of mathematical notation and its practical implications.
Antiphon said:Tau is the wrong symbol. It should be pi-bar like h and h-bar in QM.
A mathematician, a physicist, and an engineer walk into the pi bar ...
pmsrw3 said:Huh? What do you mean "pi is 1 radian"?
As long as they transmit in binary we're fine.SteveL27 said:I hope SETI knows about this. It would be a shame if the aliens are transmitting 6.28... and we're missing it![]()
Since I'm making my own calculator
dimension10 said:He makes use of Euler's identity to strengthen his claim but that doesn't make any sense.
It works with pi too.
{e}^{i\pi}=0-1
To change it to the form of Euler's identity, it would be
{e}^{i\tau}-1=0
Tau is also very annoying as writings involving tau would be very confusing. He is not even taking trigonometry and area into consideration.
Char. Limit said:Not to mention, the latter equation tells us LESS. Try taking the square root of e^{i \tau} and 1. You'll get e^{i \pi} and... ±1. So which one is e^{i \pi}? The latter equation doesn't tell us.
dimension10 said:Not too sure if you could say that. Even with pi there is a problem. It doesn't tell us \exp(i \frac{pi}{2})
disregardthat said:The point is that the equation corresponding to tau can be algebraically derived from the equation correponding to pi. So Char.limit is correct, essentially the equation for tau gives less information, because it cannot derive the equation for pi algebraically.
dimension10 said:And that for pi cannot derive that for pi/2 algebraically so there is not best equation whatsoever.
Char. Limit said:I don't think you get the meaning of the word "better". "Better" does not mean "best". "Less" does not mean "the least". I never said that e^(i pi) = -1 was the "best" equation. I said it was "better" and gave "more" information than e^(i tau) = 1, something that's undeniably true.
disregardthat said:You can't derive Fermat's last theorem either, so what?
dimension10 said:Yup, but there are an infinite number of equations better than that.
\exp(i \frac{\pi}{2})=i
\exp(i \frac{\pi}{4})=\frac{i+1}{\sqrt{2}}
\exp(i \frac{\pi}{8})=\sqrt{\frac{i+1}{\sqrt{2}}}
