Shouldn't the time dilation in cosmic voids be immense?
The discussion centers on the expansion of cosmic voids versus galaxies, highlighting that galaxies are gravitationally bound systems while cosmic voids are not. Participants clarify that "expansion" refers to the movement of galaxy clusters apart rather than individual galaxies. The concept of time dilation is deemed irrelevant in a non-stationary spacetime, as the universe's overall structure lacks time translation symmetry. The Local Group, which includes the Milky Way and Andromeda galaxies, is identified as a gravitationally bound system not influenced by cosmic expansion.
  • Understanding of gravitational binding in astrophysics
  • Familiarity with the concept of cosmic expansion
  • Knowledge of galaxy clusters and superclusters
  • Basic principles of spacetime and time dilation
  • Research the dynamics of gravitationally bound systems in astrophysics
  • Study the concept of cosmic expansion and its implications on galaxy clusters
  • Learn about the structure of the universe, including superclusters and cosmic voids
  • Explore the principles of spacetime and their relation to time dilation in cosmology
Astronomers, astrophysicists, and students of cosmology looking to deepen their understanding of cosmic structures and the dynamics of the universe.
staedtler
TL;DR
Time Dilation
Shouldn't we question why cosmic voids are expanding but not galaxies?
Space news on Phys.org
Welcome to the PF.
We require links for such questions. Can you post a couple of links to what you have been reading about this, so we can understand the context of your question better? Thank you very much.
It isn't common knowledge that the universe is expanding ..but not the volumes inside galaxies?
Sort of. You should be able to find some applicable links, no? Instead you are making us guess. You've marked the level of this thread at Basic (thank you), so if you are having trouble finding good links to start the discussion, I can help. :smile:
Also paging @phinds who can likely help with good links... :smile:
Sure, and the answer is that galaxies are gravitationally bound, while cosmic voids are not.
Talking about "volumes" expanding is meaningless. "Expansion" means things are moving apart. That's all it means.
The volumes are moving apart without gaining momentum from it. So it is not meaningless. Time dilation on the extreme end seems to add more nothingness.
"Volumes" aren't things. A much better term would be "galaxies", or names for similar objects.
Momentum is relative. Galaxies that are moving apart in the universe are certainly gaining momentum relative to each other, since their relative velocities are increasing.
If you think there is a sense in which galaxies are not gaining momentum, you will need to explain in more detail what you mean and why you think that.
staedtler said:
Time dilation
Is not even a meaningful concept in a spacetime that is not stationary, i.e., that does not have time translation symmetry. The spacetime that describes the universe as a whole is not stationary, so there is not a meaningful concept of "time dilation" for it, or for objects like galaxies that are modeled as moving in it.
Are you saying Einstein was wrong about spacetime? Some galaxies are moving towards each other ..clearly the "expansion" is not influencing them.
The Local Group is not expanding.
Not in the least. Why would you think that?
Yes. For example, our galaxy and the Andromeda galaxy.
Yes, because those galaxies are part of a larger gravitationally bound system. In the case of our galaxy and the Andromeda galaxy, both are part of the Local Group, which is gravitationally bound, and is (AFAIK) also believed to be gravitationally bound to a larger cluster of galaxies.
So a better term for the things whose moving apart, on average, is what we call the "expansion of the universe" would be "galaxy clusters" (or perhaps "superclusters", or even "supercluster complexes" in some cases), not "galaxies".
Fine with me, cosmic voids are expanding though.
Please give a reference, as you have already been asked to do. As you state it, this makes no sense, since a void, consisting of nothing, can't "expand". The fact that you often see talk like this in pop science sources does not mean it's correct.
huh? something has to be expanding ..and the cosmic voids are the only areas that make sense.
I suspect a certian amount of mass in necessary to enact spacetime. Cosmic voids don't have it, so they go bananas.
I already told you what "expanding" means: it means galaxy clusters are moving apart. That's all it means.
No, they're an area that doesn't make sense. See above.
Please review the PF rules on personal speculation.
Also, since you have refused to provide any references despite repeated requests, this thread is closed.
  • · Replies 0 ·
